as agreed, the big bad reformat landed on master, 2.13.x and 2.12.x.
Back to normal business for everybody
And oh, I’ve modified the setup so that on Travis it won’t check for local modifications, but directly
for faulty formatting (the error message should be easier to understand).
The Jenkins builds are also following the same settings
Oh, I’ve noticed there is a newer version of the formatting plugin, but as far as I could tell,
it was not fixing any bug of significant, while it was changing the formatting rules for annotations a bit,
changing several files. I skipped this upgrade to avoid adding extra noise on the commit history…
if need be, we can revisit and upgrade later I guess
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Good news, thank you Andrea !
On 06/09/2018 03:25 PM, Andrea Aime wrote:
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Andrea,
"-Dfmt.action=check" was applied only to the community build because the Travis CI script line is two commands separated by "&&" and "-Dfmt.action=check" was only appended to the script line. I have added "-Dfmt.action=check" to the first (main build) command on master, 2.13.x, and 2.12.x. We should close-reopen pull requests to ensure that their formatting is checked.
Kind regards,
Ben.
On 10/06/18 02:25, Andrea Aime wrote:
And oh, I've modified the setup so that on Travis it won't check for local
Oh, I've noticed there is a newer version of the formatting plugin, but as
on the commit history...
------------------------------------------------------- *Con riferimento
telephone or e-mail.*
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/>
New Zealand
And thanks again, Andrea. The new Maven formatter workflow is working well for me. Much better than fussing over IDE settings. Much appreciated.
Kind regards,
Ben.
On 12/06/18 19:07, Andrea Aime wrote:
Thanks Ben
On Mon, Jun 11, 2018 at 10:29 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
Andrea,
Kind regards,
Ben.
ogni
Director
New Zealand
Director
New Zealand
Andrea,
I have added a fmt.skip property on all active branches of GeoTools and GeoServer. This allows -Dfmt.skip to skip formatting. This is useful in loops of many short Maven runs of a single test (e.g. hunting intermittent failures), when formatting can otherwise take most of the time.
Kind regards,
Director
New Zealand
Thanks Ben
Il dom 24 giu 2018, 03:01 Ben Caradoc-Davies <ben@anonymised.com> ha scritto:
Andrea,
Kind regards,
Director
New Zealand
In yesterday's meeting we noticed a pull request that tried to convert many line endings from LF to CRLF. This was not detected by fmt-maven-plugin. There is a fmt-maven-plugin feature request:
https://github.com/coveo/fmt-maven-plugin/issues/32
We could add a separate check.
Kind regards,
Director
New Zealand
From this it looks we can set up a .gitattributes file to automagically convert them on check in/out.
Might be worth experimenting with?
Ian
Ian Turton
Yep, sounds like it might
Wondering if it’s going to cause trouble for people on Windows though, like,
editor wise (well, instead of them causing trouble to the rest :-p)
On Thu, Jun 28, 2018 at 11:06 AM, Ian Turton <ijturton@anonymised.com> wrote:
Ian
On Wed, 27 Jun 2018 at 22:21, Ben Caradoc-Davies <ben@anonymised.com> wrote:
In yesterday’s meeting we noticed a pull request that tried to convert
Kind regards,
Director
New Zealand
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.comsourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Ian Turton
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I think if we set it to auto it should spot for them and convert back. I’d need to resurrect my windows machine to check though, And we’d need to work out all the binary file endings we’d need to protect.
Ian
Ian
Kind regards,
Director
New Zealand
GeoTools-Devel@lists.sourceforge.net
Ian Turton
Ian Turton
On Fri, Jun 29, 2018 at 3:10 PM, Ian Turton <ijturton@anonymised.com> wrote:
I think if we set it to auto it should spot for them and convert back. I'd
need to resurrect my windows machine to check though, And we'd need to work
out all the binary file endings we'd need to protect.
Is there a way to list the ones we want the setting to act on instead? The
list would seem more simple/obvious (java, rst, txt, sld, xml, ftl, maybe
jfl)
Andrea, Ian,
This is the .gitattributes I have on my Windows ™ box for our geo-spatial services.
*.sql eol=lf
*.jpg binary
*.png binary
*.tif binary
*.gz binary
*.zip binary
*.FPT binary
This helps GIT understand what we want done with files locally. I also set my git attributes to leave files alone and stop helping with LF > CRLF > LF transitions.
Chris Snider
Senior Software Engineer
![cid:image001.png@...5124...]()
(attachments)
Is there a way to list the ones we want the setting to act on instead? The list would seem more simple/obvious (java, rst, txt, sld, xml, ftl, maybe jfl)
