On Fri, Apr 22, 2016 at 11:07 PM, Kevin Smith <smithkm@anonymised.com> wrote:
Since Justin transferred the core YSLD module into GeoTools, it seems
like it would make sense to transfer the YSLD GeoServer integration
component to GeoServer as a community module.
The module is fairly simple as all it does is make GeoServer aware of
the YSLD language, and allow for zoom levels specified in terms of
gridsets from the integrated GWC instance.
Community modules are normally exempt from Beta code freeze, but as this
is adding a whole new one rather than just a change and we've been
having so much pain with releasing 2.9, I want to check for any
objections first.
No objections here, had a quick look at the branch and indeed the only core
change
seems to be the web/app/pom reference to the new community module.
+1
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
