Geoserver failed to start after OS (Debian) update
I have been running geoserver on debian11 (bullseye) using tomcat 9, openjdk.
After a recent OS update geoserver failed to start.
Due to operational reasons I am not in the position to investigate further, other that to state
apt-mark showhold
libtomcat9-java
openjdk-11-jre
tomcat9
tomcat9-admin
tomcat9-common
tomcat9-docs
tomcat9-examples
tomcat9-user
allowed an OS update, with the geoserver service function correctly.
To clarify this was not an upgrade to bookworm (12)
The geoserver version is
  • GeoServer Version
    2.25.3
  • Git Revision
    00835315c4cc1743ceee114f20d0e4e86cc181cf
  • Build Date
    19-Jul-2024 12:30
  • GeoTools Version
    31.3 (rev 5c48493594b3ba5197f94cfe3cce7073dc37a508)
  • GeoWebCache Version
    1.25-SNAPSHOT (rev 70b38c615f940b311e4756224a66013d6d84bb81/70b38c615f940b311e4756224a66013d6d84bb81)
I hope this is of use.
You posted this to generate instead of GeoServer - users channel. I have moved this to geoserver/users.
If you want continue this discussion, subscribe to - user - OSGeo Discourse
That is not enough information to work with sadly. You have described your
environment but not the failure; and I do not have a linux machine to be
informed about … debian11.
If you look at the logs when tomcat starts geoserver it should say
something.
As an example a common failure is in ability to read the file system
location where the GEOSERVER_DATA_DIR is located. Tomcat can be configured
to sandbox file system access or something. Perhaps that was the default
when you updated?
Please have a look at the logs and report back why geoserver failed to
start - what the first error or exception was. After the first error there
are usually more (if it has problems starting up it will also have problems
shutting down).
Finally reply works
To get the logs I would have to make the service unavailable, restore the original VM, ~ 1Tb, get the logs, restore the modified (working) VM. this is not feasible.
To get the system up post the OS upgrade I initiated the following holds
apt-mark showhold
libtomcat9-java
openjdk-11-jre
tomcat9
tomcat9-admin
tomcat9-common
tomcat9-docs
tomcat9-examples
tomcat9-user
This in my opinion narrows the issue down to one of the held items.
OK, docs, examples may not be relavent, but I needed to get it working so I went for the full option
