Hello GeoServer team,
I’m encountering a strange issue while using GeoServer to serve WMS layers in a Cesium-based frontend.
Here’s the situation:
• I’m running GeoServer on Windows using the standard “startup.bat” script.
• In my Cesium app, I load WMS layers using WebMapServiceImageryProvider depending on the imagery selected by the user. When users switch layers quickly, it can lead to a situation where one layer is removed and a new one is added almost instantly.
• When user do this quickly (e.g., switching layers within 1–2 seconds), GeoServer sometimes appears to freeze — tile requests stop processing and nothing loads further.
• However, when I right-click or interact with the GeoServer console window, it suddenly resumes responding and tiles begin loading again.
Here is a snippet of the code I’m using in JavaScript:
// Load Layer
const imageryProvider = new Cesium.WebMapServiceImageryProvider({
url: SystemConfig.GeoserverWorkBase,
layers: 'GeoWorkSpace:' + id,
parameters: {
service: 'WMS',
format: 'image/png',
transparent: true,
tiled: true,
srs: 'EPSG:4326',
const imageryLayer = viewer.imageryLayers.addImageryProvider(imageryProvider);
imageryLayer._layerId = id;
// Remove Layer
const layers = viewer.imageryLayers;
for (let i = 0; i < layers.length; i++) {
const layer = layers.get(i);
if (layer._layerId === id) {
layers.remove(layer);
return;
My Questions:
- What could cause GeoServer to pause or freeze in this way? Could it be related to AWT/Swing or thread blocking when running in GUI mode?
- Is it recommended to run GeoServer in background mode to avoid this issue?
- Are there any best practices to avoid this situation when rapidly switching layers using WMS?
Any insights or suggestions would be greatly appreciated.
Thank you for your time!
Best regards.
