GeoServer on Ubuntu Server failing after restart with 504 error
Hello,
I have GeoServer installed on an Ubuntu Server. After a restart, GeoServer started failing. Although I restart the Tomcat services, it works only for a few minutes before it gives a 504 error. Can anyone help me troubleshoot this issue?
Thank you.
You will need to check both the GeoServer and Tomcat logs to see why. If you can’t work it out then you’ll need to add these details here before we can help you
Ian
