GeoServer PSC meeting notes, March 25th 2025
GeoTools / GeoServer PMC meeting - 2025-03-25
Attending
  • Torben Barsballe
  • Peter Smythe
  • Gabriel Roldan
  • Andrea Aime
  • Kevin Smith
  • Cécile Vuilleumier
  • Jody Garnett
Actions from prior meetings:
  • [image]Jody/Torben: Test geoserver-builds discourse email with Jenkins build notifications
  • [image]Peter: Will remove unloved community modules (pom.xml, docs, packaging)
  • [image]Gabe & Jody: Delay the 2.27.0 release (send new date to developer forum)
  • [image]Jody will ask developers / community to test night builds for community data dir loader.
  • [image]Jody: Meeting invite to geoserver-security list for a meeting next week at this same time
Agenda
  • Jenkins Maintenance
  • GeoServer 2.27.0 release updates
  • Do we need to keep track of modules in Jira
  • CITE testing activity update
  • GeoServer 3
  • Chit Chat
Actions
  • [image]Volunteer needed: postgis testing github workflow actionvolunteer
  • [image]aaime: geoserver-release-docker add docker prune - check in next week to see if it’s working
  • [image]Jody: make components mandatory
  • [image]Torben: Ask on Dev list if others use components
  • [image]
Jenkins Maintenance
Some item came up during maintenance that have wider applicability to the PSC
  1. PostgreSQL 12 is obsolete (not supported/available on current OS version) - Used by GeoTools DB tests
Upgrade to 14 (or newer?).
But also, GitHub actions are using 11
Q: Do we advertise a minimum version of PostgreSQL?
  • Dialect detects a few differences to for SQL generation
  • Some features require PostgreSQL 12
Q: Do we want to advertise a minimum version?
  • We would need to test if we establish a minimum
  • Could set up a workflow matrix …
    • Test from 11 to 17
    • carbon footprint, consider full matrix on “main” rather than each PR …
    • Tests are moderately heavy (5 mins to run)
  1. We are low on space on build server?
Prune unused docker: 5GB → 80GB
  • Consider auto run docker prune
  • geoserver-release-docker [Jenkins] runs frequently, maybe just tack on prune to the end of this?
  • With CITE test images gone it may be lighter :slight_smile:
docker system prune --filter “until=168h” -f (older than one week)
  1. Build failure sent message to discourse and it did not show up in discourse
  • Jody has asked in SAC channel for help; but unclear what needs to change
action:
  • postgis testing github workflow action is interesting if we have a volunteer
  • aaime: geoserver-release-docker add docker prune
    • Check in again next week to confirm this is working
  1. Public testing has shown some glitches and troubles but is mostly good!
  2. catalog load race condition:
docker run -it -p8080:8080 \ welcome-global-services-disabled
–env INSTALL_EXTENSIONS=true \
–env STABLE_EXTENSIONS=“ysld,ogcapi-features” \
docker.osgeo.org/geoserver:2.27.x
  1. Resolved with “–env GEOSERVER_DATA_DIR_LOADER_ENABLED=false”
25 Mar 16:34:07 ERROR [config.datadir] - Error preloading org.geoserver.util.EntityResolverProvider
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [jar:file:/usr/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-main-2.27-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'catalog' while setting bean property 'catalog'; nested exception is org.springframework.beans.factory.BeanCurrentlyInCreationException: Error creating bean with name 'localWorkspaceCatalog': Requested bean is currently in creation: Is there an unresolvable circular reference?
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:342)
Here is pastebin: https://pastebin.com/hHyFEfuk
  1. Reduced community modules
    Thanks Peter!
  2. jody: Could not reproduce the “service capabilities” when disabling global service.
  3. Some problems with CSP so docs were “improved” with warnings.
    Upgrading existing versions — GeoServer 2.27.x User Manual
  4. We also have a new Draft PR by Steve to handle feedback from CSP testing
  5. We had our CVE round up and are organized for release
Availability:
  • Gabe: Will look at the race condition above
  • Jody can start on draft blog post today, and ask for team review editing
  • Gabe: Monday for release artifacts
  • Peter: On hand Monday for CITE testing
  1. Jody spammed a bunch of people, by updating the tickets with no “component”
  2. This is just by the release announcement script “vulnerability” and “community”
  3. Could we make it mandatory? Yes we could …
  4. Could we make it simple?
    components simple: “geoserver”, “extension”, “community”, “vulnerability”
  5. Maybe raise with dev list
  6. Ideally we could move github issues :slight_smile: e.g. GitHub - doctrine/jira-github-issues: Scripts to migrate Jira to Github issues, GitHub - hbrands/jira-issues-importer: Python scripts for importing JIRA issues in XML format into Github Issues
Actions:
  • jody: make components mandatory
  • torben: Ask on Dev list if others use components
Peter:
  • Waiting on 2.27.0 release artifacts!
Andrea:
  • We are now passing WCS 2.0 build!
    • passes on patched tests
    • depends on Team Engine 6
    • So we pass “eventually”…
    • Jeroen: We have email indicating we can link to these issues when requesting certification
Jody:
  • The website home page:
    GeoServer implements industry standard OGC protocols
  • We will make a pull-request adding the stickers saying:
    • “certified” for WFS, WCS, etc…
    • “implementing” for WPS (that does not have a CITE test and cannot be certified)
GeoServer 3
  1. We are at 90%, please promote!
    Jody would like to start :slight_smile:
Chit Chat
Have a good release everyone!
