GeoServer setup redirect
Hi, I am trying to setup a domainname for GeoServer.
This is the domainname: https://geoserver.domainname.nl/geoserver
In the web.xml file within \webapps\geoserver\WEB-INF i have set up the following:
<context-param>
	<param-name>PROXY_BASE_URL</param-name>
	<param-value>https://geoserver.domainname.nl/geoserver</param-value>
</context-param>
When i open this link i see this:
503 Service Unavailable
No server is available to handle this request.
Am i doing this correct and/or is there any other way to set this up?
Thank you.
There are several ways to set it up, are you using the binary distribution or installing a war into Tomcat?
GeoServer checks PROXY_BASE_URL value from three locations, before checking configuration.
  1. Java System Property
    -DPROXY_BASE_URL=https://geoserver.domainname.nl/geoserver
  2. Web Application Context
    • Configuring your application server, for Tomcat this is done by editing conf/Catalina/localhost/geoserver.xml:
      <Context docBase="geoserver.war">
        <Parameter name="PROXY_BASE_URL"
                   value="https://geoserver.domainname.nl/geoserver"/>
      </Context>
    • Unzipping the geoserver.war and editing the web.xml (not recommended as you lose your setting when updating).
      <context-param>
        <param-name> PROXY_BASE_URL </param-name>
      </context-param>
  3. Environmental variable
    export PROXY_BASE_URL=https://geoserver.domainname.nl/geoserver
  4. Administration console Settings > Global (stored as part of geoserver configuration).
For more information please read Setting Application Property. It uses the example of GEOSERVER_DATA_DIR, but the same approach works for PROXY_BASE_URL.
Other tips:
Thank you for the helpful insight! I was using the war file. I got it all working now so you can close the topic. Thanks for the speedy reply!
