I've been trying to get 1.4M1 going. I may have missed something if
there are any new things to take into consideration when installing it,
but have looked and found nothing related.
I deploy the war file, then add ojdbc14.jar and gt2-oracle-spatial.jar
to the WEB-INF/lib directory.
I then start the server, but the oracle datastore isn't available, and
so when I point to my existing configuration files it breaks.
I've tried every combination of including or excluding the above files.
I've tried deploying the war file under JRun4 and Tomcat with the same
result.
When I remove 1.4M1 and put 1.3.3 on again (and the above jar files) it
works again.
Is there a bug here?
Thanks
Miles
___________________________________________________________________________
Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
Visit our web site at http://www.aad.gov.au/
Hi Miles,
I tried both the binary release and the war ( with tomcat ) and i was
able to pick up the oracle data store when i dropped the appropriate
jars in. Do you get any exceptions when restarting the server or
anything? Perhaps you can include the startup log.
-Justin
Miles Jordan wrote:
result.
works again.
Thanks
Miles
DELETE the message.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
!DSPAM:1004,44fd0615186761702038478!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Hmmmm... It should work. But 1.4-M1 is still a bit rough. How about you wait till the next release, and then we can work together and debug it, and try to do some testing on our end too.
best regards,
Chris
Miles Jordan wrote:
result.
works again.
Thanks
Miles
DELETE the message.
!DSPAM:1003,44fd0615186741775926497!
Chris Holmes
http://topp.openplans.org
