[Geoserver-users] 1.4M1/Oracle [Sec=Unclassified]
I just tried 1.4M2, with the same result. It happens on 2 machines, one
running windows 2000 server, one running windows xp. Both are running
the war version under Jrun4. The logs with included exceptions are
attached. Geoserver 1.3.4 works without a hitch on both machines.
Something about apache struts? Logs are attached.
It seems like it could be specific to Jrun4 - I don't know why it wasn't
working on Tomcat before (there may have been something I overlooked),
but I can now get it to work on Tomcat no worries (not that I really
want to use it because I need to run Jrun anyway).
Miles
-----Original Message-----
Sent: Tuesday, 19 September 2006 1:09 AM
To: Miles Jordan
Cc: geoserver-users@lists.sourceforge.net;
geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-users] 1.4M1/Oracle [Sec=Unclassified]
Hmmmm... It should work. But 1.4-M1 is still a bit rough.
How about
you wait till the next release, and then we can work together
and debug
it, and try to do some testing on our end too.
best regards,
Chris
Miles Jordan wrote:
> Hi all,
> I've been trying to get 1.4M1 going. I may have missed something if
> there are any new things to take into consideration when installing
> it, but have looked and found nothing related.
> I deploy the war file, then add ojdbc14.jar and
gt2-oracle-spatial.jar
> to the WEB-INF/lib directory.
> I then start the server, but the oracle datastore isn't
available, and
> so when I point to my existing configuration files it breaks.
> I've tried every combination of including or excluding the above
> files.
> I've tried deploying the war file under JRun4 and Tomcat
with the same
> result.
> When I remove 1.4M1 and put 1.3.3 on again (and the above
jar files)
> it works again.
> Is there a bug here?
> Thanks
> Miles
______________________________________________________________________
> _____
> Australian Antarctic Division - Commonwealth of Australia
> IMPORTANT: This transmission is intended for the addressee only. If
> you are not the intended recipient, you are notified that use or
> dissemination of this communication is strictly prohibited by
> Commonwealth law. If you have received this transmission in error,
> please notify the sender immediately by e-mail or by
telephoning +61 3 6232 3209 and DELETE the message.
> Visit our web site at http://www.aad.gov.au/
> _____
> Using Tomcat but need to do more? Need to support web
services, security?
> Get stuff done quickly with pre-integrated technology to
make your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&
dat=121642
Geoserver-users mailing list
!DSPAM:1003,44fd0615186741775926497!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
___________________________________________________________________________
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
geoserver14-err.log (2.9 KB)
geoserver14-event.log (4.59 KB)
geoserver14-out.log (25.7 KB)
