I'm trying to use Geoserver 1.6.0 RC2 with some ArcSDE data sources
and I've verified a strange issue.
I've created a SDE DataStore and 6 FeatureTypes from the same
DataStore, then I've created a web page that (using openlayers) shows
3 FeatureTypes as WMS layers.
All works well but sometimes (this behavior looks like related to
memory usage, because if i stop some windows services the issue is
somehow limited), after time of correct usage, SDE data looks like
broken (nothing appears on the screen).
The Geoserver console show an exception generated from SDE ESRI code,
something like "NoClassDefFound: com... /PlainSelect", but the data is
the same that was showed earlier!
Any suggestion on how to find the real problem behind the scenes?
Hi Diego,
it looks like the jar for a new dependency used by the geotools arcsde plugin
(jsqlparser) were not included in the arcsde extension zip file.
I opened this jira issue <http://jira.codehaus.org/browse/GEOS-1648>\.
In the mean time it would be great if you could just throw the attached jar in
your class path (geoserver's WEB-INF/lib would be fine) and check if the
issue is fixed.
cheers,
Gabriel
Any suggestion on how to find the real problem behind the scenes?-------------------------------------------------------------------------
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4045,477e0d0d294942092453641!
jsqlparser-0.3.14.jar (120 KB)
Thanks
On Jan 4, 2008 12:53 PM, Gabriel Roldán <groldan@anonymised.com> wrote:
Hi Diego,
issue is fixed.cheers,
Gabriel
> Geoserver-users@lists.sourceforge.net
Diego Guidi
http://lacorrente.blogspot.com
