[Geoserver-users] 1.6.5 + PostGIS: Getting gml:_ImplicitGeometry from GetFeature requests
Using 1.6.5 and asking for features that have WKT starting with
SRID=4326;GEOMETRYCOLLECTION(POLYGON(( …
I get this in the GetFeature response:
<gml:_ImplicitGeometry srsName=“urn:x-ogc:def:crs:EPSG:6.11.2:4326”/>
(Without any actual geometry.)
The same datastore accessed through the community-schemas datastore gives back an empty gml:_Geometry element. What’s going on?
Dustin Parker
Forward Slope, Inc.
Work: 619 299 4400
Cell: 619 277 2591
0tDaX0iWmunqkiR2WKCNG
vHUT0iWqSJHZYoI0a8d1p
E9Ilprp6QZrogbPZYoI0a
8aA0ekDQ6eyxQRo146A==
    SRID=4326;GEOMETRYCOLLECTION(POLYGON(( ...
    <gml:_ImplicitGeometry srsName="urn:x-ogc:def:crs:EPSG:6.11.2:4326"/>
The same datastore accessed through the community-schemas datastore gives back an empty gml:_Geometry element. What's going on?
I have no idea... the community schema setup replaces many core
GeoServer modules including the WFS one... I'm not at all familiar
with the community schema one so, I hope Ben has an answer for
you. To the best of my knowledge, the standard WFS module never
generates a gml:_ImplicitGeometry in the output.
Andrea Aime
OpenGeo - http://opengeo.org
But that first XML fragment is from the standard WFS module (built from SVN's 1.6.5 tag). Only the second one is from the community-schemas module (and it is probably symptomatic of the problem with the regular datastore).
Ah, I see. Any chance you can provide us with a data sample plus
request so that we can reproduce the issue?
Andrea Aime
I have no idea… the community schema setup replaces many core
GeoServer modules including the WFS one… I’m not at all familiar
But that first XML fragment is from the standard WFS module (built from SVN’s 1.6.5 tag). Only the second one is from the community-schemas module (and it is probably symptomatic of the problem with the regular datastore).
(Sorry, I didn’t mean to send that last reply directly to you.)
Okay; I’ve attached a SQL table creation script for PostgreSQL and the feature type’s info.xml. Here’s the request:
[endpoint reference]?service=WFS&request=GetFeature&typename=fsi:testGeomCollection
And the result, like before:
I can also debug and code if you can point me towards the appropriate classes.
testGeomCollection.sql.bz2 (971 Bytes)
testGeomCollection_info.xml.bz2 (465 Bytes)
Dustin Parker
Forward Slope, Inc.
Work: 619 299 4400
Cell: 619 277 2591
Hi Dustin,
Thanks for providing some data. I tries this out and it is indeed a bug with the gml3/wfs 1.1 encoder. Filing a jira issue here:
http://jira.codehaus.org/browse/GEOS-2276
Note: The gml2/wfs 1.0 encoder handles this ok.
-Justin
(Sorry, I didn't mean to send that last reply directly to you.)
Okay; I've attached a SQL table creation script for PostgreSQL and the feature type's info.xml. Here's the request:
    [endpoint
Dustin Parker
Forward Slope, Inc.
Work: 619 299 4400
Cell: 619 277 2591
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
