hi,
I use the following cql_filter on Geoserver 1.5 without problems.
&cql_filter=object_id=102|object_id=102|object_id=102|object_id=102|object_id=102|INCLUDE|INCLUDE
If I use the same filter on Geoserver 1.6 (same layers, database, configuration etc.) I get a Lexical error (see backtrace below).
Is it a bug? Has the syntax changed? Is there a solution?
thanks,
Piebe
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1" > <ServiceException>
org.geotools.filter.text.cql2.TokenMgrError: Lexical error at line 1, column 14. Encountered: "|" (124), after : ""
Details:
org.geoserver.platform.ServiceException: org.geotools.filter.text.cql2.TokenMgrError: Lexical error at line 1, column 14. Encountered: "|" (124), after : ""
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1136)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:197)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:210)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:834)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:640)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1286)
at java.lang.Thread.run(Unknown Source)
Caused by: org.geotools.filter.text.cql2.TokenMgrError: Lexical error at line 1, column 14. Encountered: "|" (124), after : ""
at org.geotools.filter.text.cql2.CQLParserTokenManager.getNextToken(CQLParserTokenManager.java:2389)
at org.geotools.filter.text.cql2.CQLParser.jj_ntk(CQLParser.java:4051)
at org.geotools.filter.text.cql2.CQLParser.MultiplicativeExpression(CQLParser.java:1876)
at org.geotools.filter.text.cql2.CQLParser.BinaryExpression(CQLParser.java:1793)
at org.geotools.filter.text.cql2.CQLParser.Expression(CQLParser.java:1789)
at org.geotools.filter.text.cql2.CQLParser.ComparissonPredicate(CQLParser.java:999)
at org.geotools.filter.text.cql2.CQLParser.Predicate(CQLParser.java:318)
at org.geotools.filter.text.cql2.CQLParser.BooleanPrimary(CQLParser.java:266)
at org.geotools.filter.text.cql2.CQLParser.BooleanFactor(CQLParser.java:219)
at org.geotools.filter.text.cql2.CQLParser.BooleanTerm(CQLParser.java:176)
at org.geotools.filter.text.cql2.CQLParser.BooleanValueExpression(CQLParser.java:129)
at org.geotools.filter.text.cql2.CQLParser.SearchCondition(CQLParser.java:98)
at org.geotools.filter.text.cql2.CQLParser.SequenceOfSearchConditions(CQLParser.java:107)
at org.geotools.filter.text.cql2.CQLParser.MultipleCompilationUnit(CQLParser.java:91)
at org.geotools.filter.text.cql2.CQL.toFilterList(CQL.java:240)
at org.geotools.filter.text.cql2.CQL.toFilterList(CQL.java:210)
at org.geoserver.wfs.kvp.CQLFilterKvpParser.parse(CQLFilterKvpParser.java:26)
at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:949)
at org.geoserver.ows.Dispatcher.init(Dispatcher.java:211)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:167)
... 39 more
</ServiceException></ServiceExceptionReport>
Piebe de Vries piebe.de.vries@anonymised.com
Geodan IT b.v. Tel: +31 (0)73 - 6925 151
President Kennedylaan 1 Fax: +31 (0)73 - 5711 333
1079 MB Amsterdam (NL) http://www.geodan.nl
