[Geoserver-users] 1.6 problems
Hello All,
I recently uprgade from 1.4 to 1.6 RC1 and now I'm noticing that I have to
make changes to many of my applications to get things to work. So my first
of what may be many questions involves a srs problem.
When I send this URL:
http://www.cei.psu.edu:8080/geoserver/wfs?request=GetFeature&srsname=EPSG:10
2003&bbox=-1371701.0291262139,2654.0932038833853,-132111.84077669913,972517.
8563106796&typename=cei:mlra_albers
Which always worked in 1.4, no returns this error:
<ows:ExceptionReport version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows
http://www.cei.psu.edu:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.x
sd">
  <ows:Exception exceptionCode="NoApplicableCode">
  <ows:ExceptionText>
java.lang.RuntimeException: Could not
      decode srs
      &apos;http://www.opengis.net/gml/srs/epsg.xml#102003&apos;
      java.lang.RuntimeException: Could not decode srs
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
The srs 102003, which I defined, still works fine with WMS.
Any thoughts?
Steve
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
Hi Stephen,
I fear that this is failing because you are not specifying the version
of wfs to be 1.0.0, and its defaulting to 1.1.0 which does srs stuff a
bit differently. Do you get the same problem is you append version=1.0.0?
-Justin
Stephen Crawford wrote:
Hello All,
sd">
  <ows:ExceptionText>
      decode srs
</ows:Exception>
Any thoughts?
Steve
Stephen Crawford
SF.Net email is sponsored by:
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services
for just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-users mailing list
!DSPAM:4007,4762df75222391804284693!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Justin,
That did not work with the specific problem I mentioned--it gives the same
error--but it helps A LOT on some of the other problems that appeared. I
didn't know I could specify which wfs version, and I was a bit irate that
the wfs gml being returned by 1.6 was so different, and I was thinking I
would have to spend half the weekend fixing a half dozen client apps. Now I
believe those fixes should be real easy. YOU MADE MY DAY!
Steve
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Justin
Deoliveira
Sent: Friday, December 14, 2007 3:43 PM
To: Stephen Crawford
Subject: Re: [Geoserver-users] 1.6 problems
Hi Stephen,
I fear that this is failing because you are not specifying the version of
wfs to be 1.0.0, and its defaulting to 1.1.0 which does srs stuff a bit
-Justin
Hello All,
have to make changes to many of my applications to get things to work.
So my first of what may be many questions involves a srs problem.
PSG:10
port.x
sd">
  <ows:ExceptionText>
      decode srs
</ows:Exception>
Any thoughts?
Steve
Stephen Crawford
It's the best place to buy or sell services for just about anything
Open Source.
tplace _______________________________________________
Justin Deoliveira
It's the best place to buy or sell services for just about anything Open
Source.
Hi Stephen,
Glad that helped!! So yeah, in 1.6 a wcs 1.1 implementation was added so
the version parameter actually matters. Unfortunately the spec requires
that 1.1 be the default, which kind of leaves all clients that "assumed"
1.0 out in the cold.
Actually, the spec does require that an exception be thrown when the
version is missing on a non-capabilities request. While this may be good
for error reporting it may be a bit harsh as well. This has been the
source of a debate over the last while.
I will open this up to others? Should be throw an exception when the
version is missing?
As for the original problem with the srs i am at a bit of a loss... it
looks like it should be ok... especially if it works with WMS and the
srs is valid. Is there any chance you can include the entire stack trace
via the error log or console?
-Justin
Justin,
Steve
Deoliveira
Hi Stephen,
-Justin
Hello All,
PSG:10
port.x
sd">
  <ows:ExceptionText>
      decode srs
</ows:Exception>
Any thoughts?
Steve
Stephen Crawford
Open Source.
Justin Deoliveira
Source.
!DSPAM:4007,4762ee25258052085621377!
Justin Deoliveira
Here's the relevent portion of the error log. I included it as an
attachment so the email doesn't mangle it too much. Thanks.
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Friday, December 14, 2007 4:09 PM
Hi Stephen,
Glad that helped!! So yeah, in 1.6 a wcs 1.1 implementation was added so the
version parameter actually matters. Unfortunately the spec requires that 1.1
Actually, the spec does require that an exception be thrown when the version
is missing on a non-capabilities request. While this may be good for error
reporting it may be a bit harsh as well. This has been the source of a
I will open this up to others? Should be throw an exception when the version
is missing?
As for the original problem with the srs i am at a bit of a loss... it looks
like it should be ok... especially if it works with WMS and the srs is
valid. Is there any chance you can include the entire stack trace via the
-Justin
Justin,
same error--but it helps A LOT on some of the other problems that
appeared. I didn't know I could specify which wfs version, and I was
a bit irate that the wfs gml being returned by 1.6 was so different,
and I was thinking I would have to spend half the weekend fixing a
half dozen client apps. Now I believe those fixes should be real easy.
YOU MADE MY DAY!
Steve
Justin Deoliveira
Hi Stephen,
-Justin
Hello All,
E
PSG:10
e
port.x
sd">
  <ows:ExceptionText>
      decode srs
</ows:Exception>
Any thoughts?
Steve
Stephen Crawford
Open Source.
e tplace _______________________________________________
Justin Deoliveira
Open Source.
Justin Deoliveira
srs_error.txt (7.64 KB)
2007-12-14 14:41:20,142 WARN [geoserver.ows] -
java.lang.RuntimeException: Could not decode srs 'http://www.opengis.net/gml/srs/epsg.xml#102003
         at org.geoserver.wfs.ReprojectingFilterVisitor.visit(ReprojectingFilterVisitor.java:103)
         at org.geotools.filter.spatial.BBOXImpl.accept(BBOXImpl.java:116)
         at org.geoserver.wfs.WFSReprojectionUtil.reprojectFilter(WFSReprojectionUtil.java:87)
         at org.geoserver.wfs.WFSReprojectionUtil.normalizeFilterCRS(WFSReprojectionUtil.java:102)
         at org.geoserver.wfs.GetFeature.toDataQuery(GetFeature.java:367)
         at org.geoserver.wfs.GetFeature.run(GetFeature.java:250)
Aah, right, it's an issue we fixed after rc1,
http://jira.codehaus.org/browse/GEOT-1563
So stay tuned for rc2 :slight_smile:
