[Geoserver-users] 1.7.0 vs 1-7-1
Dear geoserver…
I’m working with geoserver in order to display some data over Google Earth…everything works good with the 1.7.0 version. I installed the new 1.7.1 version and doesn’t work. Any ideas? Attached are the log files. Can somebody help me?
Regards
Carlos Garcia
salida71.txt (248 KB)
salida70.txt (8.83 KB)
Hi Carlos,
Nothing in the error log jumps out at me, all the errors are from Google Earth prematurely closing server connections which is normal.
However, much has changed with KML for the 1.7.1 release. What url are you using the get the kml out from GeoServer? If you are going through the reflector its default behaviour has somewhat changed for 1.7.1. Providing the request should help us narrow it down.
-Justin
Carlos Garcia wrote:
Dear geoserver…
Regards
Carlos Garcia
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can't happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hello,
I wanted to know if somebody could give me a bit of informations about WPS as explained in :
http://geoserver.org/display/GEOSDOC/4.+WPS
How can one add a process ?
Is there extra pages about the wps in geoserver ?
Is there tutorial sample somewhere online ?
Thanks to you all and best regards.
As the page states the WPS support in GeoServer is currently unsupported, and only lives as a community module in svn, nothing that is released as of this point.
That said, there are not really any supplementary docs like tutorials around for it yet. It is not really to that point yet. Andrea has been trying to get it to a functional point, not sure exactly how far along it is.
Adding a new process is done at the GeoTools api level. You can find some more docs about it here:
http://docs.codehaus.org/display/GEOTDOC/Process+Plugin
-Justin
TASSE Gilles wrote:
Hello,
Justin Deoliveira
Justin Deoliveira ha scritto:
Hum, I'll try to finally integrate some Sextante processes into it during the end of year holidays. And oh, it still does not read from
a remote WFS, still asks for an embedded collection, I should be
able to fix that during the holidays as well.
Andrea Aime
