I had 1.7.0 and we occassionally have to restart geoserver, after restarting it it is fine. Stale database connections to Oracle? That question I haven’t gotten an answer for yet.
So in the meantime, I downloaded 1.7.2 and the oracle plugins for this version (not the next generation I don’t know what that is)
The openlayers map preview works but the KML generation generateds something but the placemarks are not visible for the FEATURE_TYPE that is hooked to an oracle spatial table with points.
This worked on 1.7.0.
The demos that come with the app work and generate KML fine.
Heather
Heather A. Carter
Senior Software Engineer
727.768.8582
Heather_A_Carter@anonymised.com
PLEASE NOTE: This e-mail, including any attached files, is confidential, may be legally privileged, and is solely for the intended recipients. If you have received this e-mail in error, please destroy it and notify me immediately by reply e-mail or phone. Any unauthorized use, dissemination, disclosure, copying or printing is strictly prohibited.
Hi Heather,
In 1.7.1 the default way KML is generated was changed. Can you try generating KML from this link:
http://localhost:8080/geoserver/wms/kml?layers=<FT>&mode=refresh
Which basically generates the pre 1.7.1 method. If that works we can narrow it down to the new stuff.
-Justin
Heather A Carter wrote:
I had 1.7.0 and we occassionally have to restart geoserver, after restarting it it is fine. Stale database connections to Oracle? That question I haven't gotten an answer for yet.
So in the meantime, I downloaded 1.7.2 and the oracle plugins for this version (not the next generation I don't know what that is)
Heather
Heather A. Carter
727.768.8582
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
