[Geoserver-users] 1.7.3 and imageio-ext?
I'm trying to get 1.7.3 going and can't quite figure out how imageio-ext gets
turned on. http://geoserver.org/display/GEOSDOC/ImageIO-ext+GDAL+extensions
says "Download the proper version (OS-specific) and read the attached README
file containing installation instructions." which I did and it dutifully
installed imageio-ext beside the geoserver tree. A restart of the geoserver
did not result in the imageio plugins appearing in Welcome -> Config -> WCS
-> CoveragePlugins and I can't see any way to force them to speak to one
another.
Help?
Thanks.
Dale MacDonald
Onomy Labs
View this message in context: http://www.nabble.com/1.7.3-and-imageio-ext--tp22464370p22464370.html
on which OS are you working on?
Daniele
On Thu, Mar 12, 2009 at 2:47 AM, mrdale <mrdale@anonymised.com> wrote:
I’m trying to get 1.7.3 going and can’t quite figure out how imageio-ext gets
says “Download the proper version (OS-specific) and read the attached README
file containing installation instructions.” which I did and it dutifully
did not result in the imageio plugins appearing in Welcome → Config → WCS
→ CoveragePlugins and I can’t see any way to force them to speak to one
another.
Help?
Thanks.
Dale MacDonald
Onomy Labs
View this message in context: http://www.nabble.com/1.7.3-and-imageio-ext–tp22464370p22464370.html
Apps built with the Adobe(R) Flex(R) framework and Flex Builder™ are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse™based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
Vista ultimate 64 using 32-bit jdk
1.6.0_12
Dale.
Sent from my iPhone. Any inscrutability is attributable to Apple…or me.
On Mar 12, 2009, at 2:35 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Daniele
another.
Help?
Thanks.
Dale MacDonald
Onomy Labs
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Dale,
I guess the gt-imageio-ext-gdal extension is missing on your geoserver installation since it has been deployed on sourceforge some hours ago:
http://downloads.sourceforge.net/geoserver/geoserver-1.7.3-gdal-plugin.zip
As usual, be sure to copy all those jars on geoserver’s WEB-INF/lib folder.
Daniele.
On Thu, Mar 12, 2009 at 2:39 PM, Dale MacDonald <mrdale@anonymised.com> wrote:
1.6.0_12
Dale.
On Mar 12, 2009, at 2:35 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com107…> wrote:
Daniele
another.
Help?
Thanks.
Dale MacDonald
Onomy Labs
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
That seemed like a plausible fix. but it didn't do the trick and I suspect
it is because I'm not finding any binaries. The docs don't indicate a
source for dlls. They explicitly point at them for pre-1.7.3 but not where
to get them for the new version and the imageio-ext 1.0.1 installer doesn't
seem to install any.
Dale.
Daniele Romagnoli wrote:
Hi Dale,
As usual, be sure to copy all those jars on geoserver's WEB-INF/lib
folder.
Daniele.
1.6.0_12
Dale.
Sent from my iPhone. Any inscrutability is attributable to Apple...or
me.
Daniele
On Thu, Mar 12, 2009 at 2:47 AM, mrdale < <mrdale@anonymised.com>
gets
turned on.
<http://geoserver.org/display/GEOSDOC/ImageIO-ext+GDAL+extensions&gt;
README
geoserver
WCS
another.
Help?
Thanks.
Dale MacDonald
Onomy Labs
<http://www.nabble.com/1.7.3-and-imageio-ext--tp22464370p22464370.html&gt;
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
easily build your RIAs with Flex Builder, the Eclipse(TM)based
development
Download the free 60 day trial. <http://p.sf.net/sfu/www-adobe-com&gt;
<Geoserver-users@lists.sourceforge.net>
<https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
<http://www.geo-solutions.it>http://www.geo-solutions.it
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
View this message in context: http://www.nabble.com/1.7.3-and-imageio-ext--tp22464370p22483438.html
OK I grabbed the dlls and gdal data from the earlier versions and now teh
plugins show up and at least the MrSID one works.
Dale.
suspect it is because I'm not finding any binaries. The docs don't
indicate a source for dlls. They explicitly point at them for pre-1.7.3
but not where to get them for the new version and the imageio-ext 1.0.1
installer doesn't seem to install any.
Dale.
Hi Dale,
folder.
Daniele.
1.6.0_12
Dale.
me.
Daniele
imageio-ext
gets
turned on.
README
dutifully
geoserver
WCS
one
another.
Help?
Thanks.
Dale MacDonald
Onomy Labs
and
development
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
development
View this message in context: http://www.nabble.com/1.7.3-and-imageio-ext--tp22464370p22483759.html
Dale,
the installer should show you the path where it will install the GDAL libraries. (see the description tab when you select the “GDAL Libraries” check box during the modules selection).
Can you check that location and see whether files are placed there after the installation?
Let me know,
Daniele
Dale.
mrdale wrote:
That seemed like a plausible fix. but it didn’t do the trick and I
suspect it is because I’m not finding any binaries. The docs don’t
installer doesn’t seem to install any.
Dale.
Hi Dale,
folder.
Daniele.
1.6.0_12
Dale.
me.
Daniele
imageio-ext
gets
turned on.
<http://geoserver.org/display/GEOSDOC/ImageIO-ext+GDAL+extensions>
README
dutifully
geoserver
WCS
one
another.
Help?
Thanks.
Dale MacDonald
Onomy Labs
<http://www.nabble.com/1.7.3-and-imageio-ext–tp22464370p22464370.html>
and
development
Download the free 60 day trial. <http://p.sf.net/sfu/www-adobe-com>
<https://lists.sourceforge.net/lists/listinfo/geoserver-users>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
development
View this message in context: http://www.nabble.com/1.7.3-and-imageio-ext–tp22464370p22483759.html
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
