[Geoserver-users] 1.7.4 multiple instances of geoserver not working
I want to use multiple instances of geoserver in tomcat. This used to work fine (1.6.3) but trying this with 1.7.4 gives the error below. Whatever instance of geoserver starts first has no problem but any instance that tries to starts after that leads to the error. How can I prevent this? It seems to have to do something with geowebcache which I do need but apparently tries to start anyway (how can I turn it off?).
thanks,
Piebe
15 May 16:03:08 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcMetaStore' defined in URL [jar:file:/D:/Apache/tomcat2_6.0/webapps/wionsysteem-geoserver-wion/WEB-INF/lib/gwc-1.7.4.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend]: Constructor threw exception; nested exception is org.geowebcache.storage.StorageException: Database may be already in use: Locked by another process. Possible solutions: close all other connection(s); use the server mode [90020-110]
    at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
    at java.security.AccessController.doPrivileged(Native Method)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
    at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
    at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
    at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
    at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
    at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
    at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
    at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3843)
    at org.apache.catalina.core.StandardContext.start(StandardContext.java:4342)
    at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1247)
    at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:604)
    at org.apache.catalina.manager.HTMLManagerServlet.doGet(HTMLManagerServlet.java:129)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
    at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:525)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
    at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
    at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
    at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
    at java.lang.Thread.run(Thread.java:619)
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend]: Constructor threw exception; nested exception is org.geowebcache.storage.StorageException: Database may be already in use: Locked by another process. Possible solutions: close all other connection(s); use the server mode [90020-110]
    at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
    at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
    at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
    ... 37 more
Caused by: org.geowebcache.storage.StorageException: Database may be already in use: Locked by another process. Possible solutions: close all other connection(s); use the server mode [90020-110]
    at org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend.<init>(JDBCMetaBackend.java:54)
    at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
    at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
    at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
    at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
    at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
    ... 39 more
  Piebe de Vries piebe.de.vries@anonymised.com
  Geodan IT b.v. Tel: +31 (0)73 - 6925 151
  President Kennedylaan 1 Fax: +31 (0)73 - 5711 333
  1079 MB Amsterdam (NL) http://www.geodan.nl
Just delete WEB-INF/lib/gwc*.jar and restart. It will fail gracefully in the next release.
-Arne
thanks,
Piebe
    ... 37 more
    ... 39 more
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Arne, I was wondering, where is the db kept?
Wouldn't it make sense to have it stored in the data directory? In
this case each instance would have its own?
Andrea Aime
By default it is stored in ${GEOSERVER_DATA_DIR}/gwc/meta_jdbc_h2
I vaguely remember running into problems that we concluded were due to running multiple GS instances against the same directory. So until recently I had assumed this was something we discourage, hence the code doesn't play nice with this scenario. However, standing corrected on the issue, I think it may have been issues related to 1.5.x vs 1.6.x, at least I "learned" this right after I started.
H2 has an automatic mode that lets it use TCP to connect when embedded fails. However, that only works if the processes are started on the same machine, so it doesn't really solve the problem.
In 2.0 there will be an environment variable to disable the GWC metastore completely, or you can set the JDBC URL through an context / environment variable. It's really a pity we have to(?) hide the applicationContext.xml files in the jars, they're nice for advanced configuration like this.
-Arne
Arne Kepp
We have to... yeah, we have to, since in order to have those in WEB-INF/classes we'd need to move those files into the web module,
giving up plugin :slight_smile:
The idea would be that applicationContext.xml represents the static
wiring of the application, everything that needs to be modifiable
at deploy time should be stored as a configuration file in the
data directory (eventually be created automagically when missing
the first time the module/extension is used).
Andrea Aime
