Hello Justin,
Thank you for the reply. I have installed GeoServer straight from the .exe that i downloaded. At first, my 8080 port was being used by my Oracle TNSlistener. I didnt want GeoServer to run on any other port than 8080 so I blew out my instance of oracle and will reinstall when I get this geoserver prob solved. Solved that prob and then unistalled and reinstalled the geoserver .exe. Started up the service, ran fine on port 8080. Its just when I go to administrator site that I get the 503 error. Oh, and I am accessing it through http://localhost:8080/geoserver/welcome
Any other ideas?
Thanks ahead of time,
Tom
Hi Tom,
Hmmm... quite strange. My only thought would be that perhaps oracle or some other service is running on port 8080. The reason i say that is because i have never seen GeoServer give back a 503 before.
Can you try changing the port GeoServer is running on, and see if you get a 503 in a different port. There are instructions on how to do this here:
http://geoserver.org/pages/viewpage.action?pageId=1278052
Change it to something like 9090 and then try accessing it from there. Let us know how it goes or if you have problems changing the port.
-Justin
Tomas Lopes wrote:
Hello Justin,
Thank you for the reply. I have installed GeoServer straight from the .exe that i downloaded. At first, my 8080 port was being used by my Oracle TNSlistener. I didnt want GeoServer to run on any other port than 8080 so I blew out my instance of oracle and will reinstall when I get this geoserver prob solved. Solved that prob and then unistalled and reinstalled the geoserver .exe. Started up the service, ran fine on port 8080. Its just when I go to administrator site that I get the 503 error. Oh, and I am accessing it through http://localhost:8080/geoserver/welcome.do>
Any other ideas?
Tom------------------------------------------------------------------------
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/------------------------------------------------------------------------
Geoserver-users mailing list
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
