You can see what was the white strips I was writing about. The raster file
displayed on the left side of the map has a overlapping area with the raster
file displayed at the right side of the map. This area as no data and is
rendered as white pixel. This map is what geoserver rendere the mosaic when
in the coverage config section I don't insert a transparent color
this is what I described as white map. I saved it as a png file on my client
but it shows the same. All pixel white
Ciao Stefano,
one thing, when you say "but I always got a white map" you are
referring to the OL preview?
Notice that the background color for OL is white therefore if you ask
for PNG and set the transparency color for the mosaic to white nothing
will apparently change, you need to save that file to check if it
really has transparent background.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Fri, Feb 13, 2009 at 10:29 AM, Stefano Iacovella
<stefano.iacovella@anonymised.com> wrote:
> Ciao Simone
> 1) Oops! I'm usind the Ol preview built in in Geoserver demo and it
> defaulkt
> to jpg. I made a png (8 and 24 bit) request on the same mosaic but I
> always
> got a white map. The geoserver.log lists:
> 2009-02-13 10:23:34,787 DEBUG [gce.imagemosaic] - Mosaic created
> 2009-02-13 10:23:35,191 INFO [coverage.grid] - Creates a photographic
> view
> of grid coverage "mos" using operation "Lookup".
> 2009-02-13 10:23:35,192 DEBUG [geotools.rendering] - Drawing coverage
> GridCoverage2D["mos", GeneralEnvelope[(1443666.843461, 4511022.104),
> (1458139.073441, 4522902.623206)], DefaultProjectedCRS["Monte Mario /
> Italy
> zone 1"]]
> ? RenderedSampleDimension("mos":[0.0 ... 255.0])
> ? ? Category("mos":[0...255])
> ? Image=RenderedOp["Mosaic"] as views [NATIVE, PACKED, RENDERED,
> GEOPHYSICS]
> 2009-02-13 10:23:35,193 DEBUG [geotools.rendering] - Transforming
> coverage
> envelope with transform PARAM_MT["Affine",
> PARAMETER["num_row", 3],
> PARAMETER["num_col", 3]]
> 2009-02-13 10:23:35,193 DEBUG [geotools.rendering] - Using interpolation
> javax.media.jai.InterpolationNearest@anonymised.com
> 2009-02-13 10:23:35,193 DEBUG [geotools.rendering] - Raster Symbolizer
> 2009-02-13 10:23:35,195 DEBUG [geotools.rendering] -
> clonedFinalWorldToGrid
> AffineTransform[[1.055670103092791, 0.0, 143.99999999999272], [-0.0,
> 1.048155104660409, 97.84490151557839]]
> 2009-02-13 10:23:36,318 DEBUG [geotools.rendering] - Raster rendered
> 2009-02-13 10:23:36,318 DEBUG [geotools.rendering] - Style cache hit
> ratio:
> NaN , hits 0, requests 0
> 2009-02-13 10:23:36,319 DEBUG [renderer.shape] - Style cache hit ratio:
> NaN
> 2009-02-13 10:23:36,319 DEBUG [wms.responses] - asking delegate for
> write to
> org.geoserver.ows.DispatcherOutputStream@anonymised.com
> 2009-02-13 10:23:36,319 DEBUG [map.png] - Writing png image ...
> 2009-02-13 10:23:36,320 DEBUG [geotools.image] - Encoded input image for
> png
> writer
> 2009-02-13 10:23:36,320 DEBUG [geotools.image] - Getting a writer
> 2009-02-13 10:23:36,320 DEBUG [geotools.image] - Setting write
> parameters
> for this writer
> 2009-02-13 10:23:36,321 DEBUG [geotools.image] - Writer is NOT native
> 2009-02-13 10:23:36,321 DEBUG [geotools.image] - About to write png
> image
> 2009-02-13 10:23:36,721 DEBUG [map.png] - Writing png image ... done!
> 2) I'm sending you the files. I made them form the original tif/tfw
> files
> with gdal_transfrm using the -co "NBITS=8" parameter while the previous
> were
> produced with the "NBITS=1" value
> 2009/2/12 Simone Giannecchini <simone.giannecchini@anonymised.com>
>> Ciao Stefano,
>> two things:
>> 1> you are requesting a JPEG transparency won't work anyway, try png
>> 2> can you send me this new dataset, just out of curiosity, I'd like
>> to play with it.
>> Thanks for letting me use the other data as test case.
>> Simone.
>> GeoSolutions S.A.S.
>> Via Carignoni 51
>> 55041 Camaiore (LU)
>> Italy
>> fax: +39 0584983027
>> On Thu, Feb 12, 2009 at 6:01 PM, Stefano Iacovella
>> > Ciao Simone
>> > 2) yes you can upload the samples I sent you to jira
>> > 1)
>> > Meanwhile I transformed the tiff in RGB or at least I tried to do it
>> > the gdalinfo of the new files is this:
>> > Driver: GTiff/GeoTIFF
>> > Files: 441130.tiff
>> > Size is 11654, 9901
>> > Coordinate System is:
>> > PROJCS["Monte Mario / Italy zone 1",
>> > GEOGCS["Monte Mario",
>> > DATUM["Monte_Mario",
>> > SPHEROID["International 1924",6378388,297.000000000005,
>> > AUTHORITY["EPSG","7022"]],
>> > AUTHORITY["EPSG","6265"]],
>> > PRIMEM["Greenwich",0],
>> > UNIT["degree",0.0174532925199433],
>> > AUTHORITY["EPSG","4265"]],
>> > PROJECTION["Transverse_Mercator"],
>> > PARAMETER["latitude_of_origin",0],
>> > PARAMETER["central_meridian",9],
>> > PARAMETER["scale_factor",0.9996],
>> > PARAMETER["false_easting",1500000],
>> > PARAMETER["false_northing",0],
>> > UNIT["metre",1,
>> > AUTHORITY["EPSG","9001"]],
>> > AUTHORITY["EPSG","3003"]]
>> > Origin = (1443709.606224609538913,4522902.623206349089742)
>> > Pixel Size = (0.634920634920640,-0.634920634920640)
>> > Metadata:
>> > AREA_OR_POINT=Area
>> > TIFFTAG_XRESOLUTION=0.015699999
>> > TIFFTAG_YRESOLUTION=0.015699999
>> > TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
>> > Image Structure Metadata:
>> > INTERLEAVE=BAND
>> > Corner Coordinates:
>> > Upper Left ( 1443709.606, 4522902.623) ( 8d19'55.86"E,
>> > 40d51'16.33"N)
>> > Lower Left ( 1443709.606, 4516616.274) ( 8d19'57.91"E,
>> > 40d47'52.48"N)
>> > Upper Right ( 1451108.971, 4522902.623) ( 8d25'11.87"E,
>> > 40d51'18.04"N)
>> > Lower Right ( 1451108.971, 4516616.274) ( 8d25'13.64"E,
>> > 40d47'54.19"N)
>> > Center ( 1447409.289, 4519759.449) ( 8d22'34.82"E,
>> > 40d49'35.29"N)
>> > Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
>> > NoData Value=255
>> > Color Table (RGB with 256 entries)
>> > 0: 255,255,255,255
>> > 1: 0,0,0,255
>> > 2: 0,0,0,255
>> > 255: 0,0,0,255
>> > Now I have no more exception with InputTransparentColor set to
>> > #FFFFFF
>> > but I
>> > get a white map
>> > the geoserver.log contains the following lines
>> > 2009-02-12 17:57:40,180 DEBUG [wms.responses] - setting up map
>> > 2009-02-12 17:57:40,182 DEBUG [gce.imagemosaic] - Connected mosaic
>> > reader to
>> > its data store
>> > file:/home/stefano/Scrivania/CTR_RAS/MINI_MOSAICO/mos.shp
>> > 2009-02-12 17:57:40,182 DEBUG [data.shapefile] - Read lock:
>> > file:/home/stefano/Scrivania/CTR_RAS/MINI_MOSAICO/mos.shp by
>> > org.geotools.data.shapefile.shp.ShapefileReader
>> > 2009-02-12 17:57:40,182 TRACE [data.shapefile] - Shapefile Reader has
>> > been
>> > opened. Number open: 1
>> > 2009-02-12 17:57:40,183 DEBUG [data.shapefile] - Read lock:
>> > file:/home/stefano/Scrivania/CTR_RAS/MINI_MOSAICO/mos.dbf by
>> > org.geotools.data.shapefile.dbf.DbaseFileReader
>> > 2009-02-12 17:57:40,183 TRACE [data.shapefile] - Dbase File Reader
>> > has
>> > been
>> > 2009-02-12 17:57:40,184 DEBUG [data.shapefile] - Read lock:
>> > file:/home/stefano/Scrivania/CTR_RAS/MINI_MOSAICO/mos.prj by
>> > org.geotools.data.shapefile.prj.PrjFileReader
>> > 2009-02-12 17:57:40,184 TRACE [data.shapefile] - PRJ reader has been
>> > opened.
>> > Number open: 1
>> > 2009-02-12 17:57:40,189 DEBUG [data.shapefile] - Read lock:
>> > 2009-02-12 17:57:40,189 TRACE [data.shapefile] - PRJ reader has been
>> > closed.
>> > Number open: 0
>> > 2009-02-12 17:57:40,189 TRACE [data.shapefile] - Dbase File Reader
>> > has
>> > been
>> > closed. Number open: 0
>> > 2009-02-12 17:57:40,189 TRACE [data.shapefile] - Shapefile Reader has
>> > been
>> > 2009-02-12 17:57:40,190 DEBUG [gce.imagemosaic] - About to create
>> > index
>> > 2009-02-12 17:57:40,190 DEBUG [data.shapefile] - Read lock:
>> > 2009-02-12 17:57:40,190 TRACE [data.shapefile] - Shapefile Reader has
>> > been
>> > 2009-02-12 17:57:40,191 DEBUG [data.shapefile] - Read lock:
>> > 2009-02-12 17:57:40,191 TRACE [data.shapefile] - Dbase File Reader
>> > has
>> > been
>> > 2009-02-12 17:57:40,193 DEBUG [data.shapefile] - Read lock:
>> > 2009-02-12 17:57:40,194 TRACE [data.shapefile] - Shapefile Reader has
>> > been
>> > 2009-02-12 17:57:40,194 DEBUG [data.shapefile] - Read lock:
>> > 2009-02-12 17:57:40,194 TRACE [data.shapefile] - Dbase File Reader
>> > has
>> > been
>> > 2009-02-12 17:57:40,194 DEBUG [gce.imagemosaic] - Created index
>> > 2009-02-12 17:57:40,194 DEBUG [gce.imagemosaic] - Highest res 0.6 0.6
>> > 2009-02-12 17:57:40,196 DEBUG [wms.map] - setting up 800x616 image
>> > 2009-02-12 17:57:40,236 DEBUG [renderer.shape] - Affine Transform is
>> > AffineTransform[[0.035378100037628, 0.0, -50836.19000897012], [0.0,
>> > -0.035378100037629, 160058.54636575168]]
>> > 2009-02-12 17:57:40,237 DEBUG [geotools.styling] - number of fts set
>> > 1
>> > 2009-02-12 17:57:40,237 DEBUG [geotools.rendering] - processing 1
>> > stylers
>> > for http://www.opengis.net/gmlGridCoverage
>> > 2009-02-12 17:57:40,237 DEBUG [geotools.rendering] - creating rules
>> > for
>> > scale denominator - 100,950.265
>> > 2009-02-12 17:57:40,237 DEBUG [geotools.rendering] - added attribute
>> > grid
>> > params
>> > 2009-02-12 17:57:40,237 DEBUG [geotools.rendering] - Querying layer
>> > GridCoverage with bbox: ReferencedEnvelope[1436939.517806234 :
>> > 1459552.377149984, 4506814.842972493 : 4524226.74466718]
>> > 2009-02-12 17:57:40,238 DEBUG [geotools.rendering] - rendering Raster
>> > for
>> > feature org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com -
>> > org.geotools.gce.imagemosaic.ImageMosaicReader@anonymised.com
>> > 2009-02-12 17:57:40,239 DEBUG [gce.imagemosaic] - Reading mosaic from
>> > 2009-02-12 17:57:40,239 DEBUG [gce.imagemosaic] - Highest res 0.6 0.6
>> > 2009-02-12 17:57:40,240 DEBUG [gce.imagemosaic] - Creating mosaic to
>> > comply
>> > with envelope GeneralEnvelope[(1436939.517806234, 4506814.842972493),
>> > (1459552.377149984, 4524226.74466718)] crs PROJCS["Monte Mario /
>> > Italy
>> > zone
>> > 1",
>> > SPHEROID["International 1924", 6378388.0, 297.000000000005,
>> > PRIMEM["Greenwich", 0.0],
>> > UNIT["degree", 0.017453292519943295],
>> > AXIS["Longitude", EAST],
>> > AXIS["Latitude", NORTH],
>> > PARAMETER["central_meridian", 9.0],
>> > PARAMETER["latitude_of_origin", 0.0],
>> > PARAMETER["scale_factor", 0.9996],
>> > PARAMETER["false_easting", 1500000.0],
>> > PARAMETER["false_northing", 0.0],
>> > UNIT["m", 1.0],
>> > AXIS["x", EAST],
>> > AXIS["y", NORTH],
>> > AUTHORITY["EPSG","3003"]] dim
>> > java.awt.Rectangle[x=0,y=0,width=800,height=616]
>> > 2009-02-12 17:57:40,241 DEBUG [gce.imagemosaic] - loading tile for
>> > envelope
>> > ReferencedEnvelope[1443666.843461 : 1458139.073441, 4511022.104 :
>> > 4522902.623206]
>> > 2009-02-12 17:57:40,241 DEBUG [gce.imagemosaic] - Trying to use the
>> > index...
>> > 2009-02-12 17:57:40,241 DEBUG [gce.imagemosaic] - Index does not need
>> > to
>> > be
>> > created...
>> > 2009-02-12 17:57:40,241 DEBUG [gce.imagemosaic] - Index Loaded
>> > 2009-02-12 17:57:40,241 DEBUG [gce.imagemosaic] - We have 4 tiles to
>> > load
>> > 2009-02-12 17:57:40,241 DEBUG [gce.imagemosaic] - Loading level 0
>> > with
>> > subsampling factors 47 47
>> > 2009-02-12 17:57:40,241 DEBUG [gce.imagemosaic] - About to read image
>> > number
>> > 0
>> > 2009-02-12 17:57:40,241 DEBUG [gce.imagemosaic] - File found
>> > 2009-02-12 17:57:40,242 DEBUG [gce.imagemosaic] - Just read image
>> > number
>> > 0
>> > 2009-02-12 17:57:40,258 DEBUG [gce.imagemosaic] - Adding to mosaic
>> > image
>> > number 0
>> > 2009-02-12 17:57:40,259 DEBUG [gce.imagemosaic] - Support for alpha
>> > on
>> > input
>> > image number 0
>> > 2009-02-12 17:57:40,275 DEBUG [gce.imagemosaic] - About to read image
>> > number
>> > 1
>> > 2009-02-12 17:57:40,275 DEBUG [gce.imagemosaic] - File found
>> > 2009-02-12 17:57:40,276 DEBUG [gce.imagemosaic] - Just read image
>> > number
>> > 1
>> > 2009-02-12 17:57:40,276 DEBUG [gce.imagemosaic] - Adding to mosaic
>> > image
>> > number 1
>> > 2009-02-12 17:57:40,292 DEBUG [gce.imagemosaic] - Support for alpha
>> > on
>> > input
>> > image number 1
>> > 2009-02-12 17:57:40,295 DEBUG [gce.imagemosaic] - About to read image
>> > number
>> > 2
>> > 2009-02-12 17:57:40,295 DEBUG [gce.imagemosaic] - File found
>> > 2009-02-12 17:57:40,296 DEBUG [gce.imagemosaic] - Just read image
>> > number
>> > 2
>> > 2009-02-12 17:57:40,296 DEBUG [gce.imagemosaic] - Adding to mosaic
>> > image
>> > number 2
>> > 2009-02-12 17:57:40,312 DEBUG [gce.imagemosaic] - Support for alpha
>> > on
>> > input
>> > image number 2
>> > 2009-02-12 17:57:40,315 DEBUG [gce.imagemosaic] - About to read image
>> > number
>> > 3
>> > 2009-02-12 17:57:40,316 DEBUG [gce.imagemosaic] - File found
>> > 2009-02-12 17:57:40,316 DEBUG [gce.imagemosaic] - Just read image
>> > number
>> > 3
>> > 2009-02-12 17:57:40,317 DEBUG [gce.imagemosaic] - Adding to mosaic
>> > image
>> > number 3
>> > 2009-02-12 17:57:40,333 DEBUG [gce.imagemosaic] - Support for alpha
>> > on
>> > input
>> > image number 3
>> > 2009-02-12 17:57:40,336 DEBUG [gce.imagemosaic] - Loaded bbox
>> > Env[1443666.843460616 : 1458139.0734409676, 4511022.103999999 :
>> > 4522902.623206349] while requested bbox
>> > 4506814.842972493), (1459552.377149984, 4524226.74466718)]
>> > 2009-02-12 17:57:40,337 DEBUG [gce.imagemosaic] - Mosaic created
>> > 2009-02-12 17:57:41,035 INFO [coverage.grid] - Creates a photographic
>> > view
>> > 2009-02-12 17:57:41,037 DEBUG [geotools.rendering] - Drawing coverage
>> > Italy
>> > zone 1"]]
>> > GEOPHYSICS]
>> > 2009-02-12 17:57:41,037 DEBUG [geotools.rendering] - Transforming
>> > coverage
>> > 2009-02-12 17:57:41,037 DEBUG [geotools.rendering] - Using
>> > interpolation
>> > 2009-02-12 17:57:41,038 DEBUG [geotools.rendering] - Raster
>> > Symbolizer
>> > Symbolizer
>> > 2009-02-12 17:57:41,039 DEBUG [geotools.rendering] -
>> > AffineTransform[[1.055670103092791, 0.0, 238.00000000000728], [-0.0,
>> > 1.048155104660409, 46.84490151560749]]
>> > 2009-02-12 17:57:43,084 DEBUG [geotools.rendering] - Raster rendered
>> > 2009-02-12 17:57:43,085 DEBUG [geotools.rendering] - Style cache hit
>> > ratio:
>> > 2009-02-12 17:57:43,085 DEBUG [renderer.shape] - Style cache hit
>> > ratio:
>> > NaN
>> > 2009-02-12 17:57:43,085 DEBUG [wms.responses] - asking delegate for
>> > write to
>> > 2009-02-12 17:57:43,099 DEBUG [geotools.image] - Encoding input image
>> > to
>> > write out as JPEG.
>> > 2009-02-12 17:57:43,099 DEBUG [geotools.image] - Getting a JPEG
>> > writer
>> > and
>> > configuring it.
>> > 2009-02-12 17:57:43,100 DEBUG [geotools.image] - Writing out...
>> > I didn't specify LZW compression but I'll give it a try
>> >> Ciao Stefano,
>> >> I inspected a bit further and the problem is related to how the 1
>> >> bit
>> >> compression is managed by both imageio and geotools as well.
>> >> I will fix them both.
>> >> Meanwhile:
>> >> 1> can you try to envode as plain RGB but using LZW compression to
>> >> have smaller files?
>> >> 2> can I use e of your sample images as sample dataa to open upa
>> >> jira?
>> >> Simone.
>> >> GeoSolutions S.A.S.
>> >> Via Carignoni 51
>> >> 55041 Camaiore (LU)
>> >> Italy
>> >> fax: +39 0584983027
>> >> On Thu, Feb 12, 2009 at 11:25 AM, Stefano Iacovella
>> >> > Ciao Simone
>> >> > thank you for the kindly support
>> >> > It was my fault I replied directly to Simone's mailbox. We come
>> >> > back
>> >> > to
>> >> > the
>> >> > list hoping we'll find a solution and it may be useful to someone
>> >> > else.
>> >> > Coming to the topic I get the original tif+tfw file and transform
>> >> > them
>> >> > to
>> >> > the geotiff format. May be I made some errors in the
>> >> > transformation.
>> >> > this is
>> >> > the output of gdalinfo on the original file:
>> >> > Files: CTR_OLD/564090.tif
>> >> > Size is 11653, 8994
>> >> > Coordinate System is `'
>> >> > Origin = (1442261.101999999955297,4328093.219998572021723)
>> >> > Pixel Size = (0.634999999841250,-0.634999999841250)
>> >> > Metadata:
>> >> > TIFFTAG_XRESOLUTION=15.748
>> >> > TIFFTAG_YRESOLUTION=15.748
>> >> > COMPRESSION=CCITTFAX4
>> >> > INTERLEAVE=BAND
>> >> > Corner Coordinates:
>> >> > Upper Left ( 1442261.102, 4328093.220)
>> >> > Lower Left ( 1442261.102, 4322382.030)
>> >> > Upper Right ( 1449660.757, 4328093.220)
>> >> > Lower Right ( 1449660.757, 4322382.030)
>> >> > Center ( 1445960.929, 4325237.625)
>> >> > Band 1 Block=512x512 Type=Byte, ColorInterp=Palette
>> >> > Overviews: 146x112
>> >> > NBITS=1
>> >> > Color Table (RGB with 2 entries)
>> >> > 0: 255,255,255,255
>> >> > 1: 0,0,0,255
>> >> > I use this parameters to transform them in geotiff:
>> >> > gdal_translate -of Gtiff -co "COMPRESS=NONE" -co "TILED=YES" -co
>> >> > "NBITS=1"
>> >> > -a_srs "EPSG:3003" $file $newfile
>> >> > May be of any help change any of this parameters?
>> >> > The o.s. is UBUNTU 8.10, JDK 1.6.0_10-b33. Geoserver is 1.7.2 with
>> >> > GDAL
>> >> > plugin.
>> >> > Could it be useful if I disable the JAI support?
>> >> > Thanks again
>> >> >> Ciao Simone,
>> >> >> quick progress update (sono parecchio indaffarato sti giorni
>> >> >> purtroppo).
>> >> >> Allora innanzitutto per tua sfortuna stai usando un tipo di dato
>> >> >> che
>> >> >> attualmente manda in crash la pipeline di rendering del java2d su
>> >> >> 2
>> >> >> delle
>> >> >> mie 3 macchine su cui ho testato. Stai usando tiff black - white
>> >> >> che
>> >> >> sono
>> >> >> trasformate in una palette a 1 bit e questo crea imbarazzi
>> >> >> notevoli
>> >> >> alla
>> >> >> pipelina, Ho cmq trovato un workaround.
>> >> >> Se tu non sei incorso in questo problema ti sarei grato se tu
>> >> >> potessi
>> >> >> darmi qualche dettaglio sulla piattaforma di test (OS
>> >> >> soprattutto) e
>> >> >> sulla
>> >> >> versione di java. La pipelina di rendering cambia a seconda di OS
>> >> >> e
>> >> >> versione
>> >> >> di java (OGL, Direct3D, etc..).
>> >> >> Per il secondo problema ho riprodotto, ma non ancora fixxato.
>> >> >> Domani
>> >> >> dovrei dare un colpo definitivo.
>> >> >> ti tengo aggioranto,
>> >> >> Simone.
>> >> >> GeoSolutions S.A.S.
>> >> >> Via Carignoni 51
>> >> >> 55041 Camaiore (LU)
>> >> >> Italy
>> >> >> fax: +39 0584983027
>> >> >> On Mon, Feb 9, 2009 at 9:13 AM, Stefano Iacovella
>> >> >>> Ciao Simone
>> >> >>> ti allego un archivio con i quattro fotogrammi ed i file con i
>> >> >>> metadati
>> >> >>> di costruzione del mosaico.
>> >> >>> Per i risultati ed eventuali altre prove ovviamente ci sentiamo
>> >> >>> sulla
>> >> >>> ml
>> >> >>> pubblica.
>> >> >>> Grazie mille per il supporto
>> >> >>> 2009/2/8 Simone Giannecchini
>> >> >>>> Ciao Stefano, mettila pure dove ti torna meglio.
>> >> >>>> L'importante è continuare la discussione sulla ml pubblica.
>> >> >>>> Simone.
>> >> >>>> GeoSolutions S.A.S.
>> >> >>>> Via Carignoni 51
>> >> >>>> 55041 Camaiore (LU)
>> >> >>>> Italy
>> >> >>>> fax: +39 0584983027
>> >> >>>> On Sun, Feb 8, 2009 at 10:11 PM, Stefano Iacovella
>> >> >>>> > Ciao Simone
>> >> >>>> > I can email you a smaple of four files that should be enough
>> >> >>>> > for
>> >> >>>> > building a
>> >> >>>> > mosaic. If you prefer I can manage to make them availabe on a
>> >> >>>> > public
>> >> >>>> > url
>> >> >>>> > avoinding to fill your mailbox.
>> >> >>>> > Thanks a lot for the answer
>> >> >>>> > Stefano Iacovella
>> >> >>>> >> Ciao Stefano,
>> >> >>>> >> the correct way to obtain what you need would be using the
>> >> >>>> >> InputTransparentColor. However, there are various
>> >> >>>> >> bugs/limitations
>> >> >>>> >> in
>> >> >>>> >> JAI as far as managing transparency with mosaic which I
>> >> >>>> >> tried
>> >> >>>> >> to
>> >> >>>> >> workaround (apparently with not much success
>> >> >>>> >> Could you make available some sample data for testing?
>> >> >>>> >> Simone.
>> >> >>>> >> GeoSolutions S.A.S.
>> >> >>>> >> Via Carignoni 51
>> >> >>>> >> 55041 Camaiore (LU)
>> >> >>>> >> Italy
>> >> >>>> >> fax: +39 0584983027
>> >> >>>> >> On Fri, Feb 6, 2009 at 5:11 PM, Stefano Iacovella
>> >> >>>> >> > I've read a few post on the nabble archive about how to
>> >> >>>> >> > handle
>> >> >>>> >> > transparency
>> >> >>>> >> > with raster and also had a look at
>> >> >>>> >> > http://geoserver.org/display/GEOSDOC/RasterSymbolizer.
>> >> >>>> >> > Eventually it seems I've not understood how to render
>> >> >>>> >> > raster
>> >> >>>> >> > with
>> >> >>>> >> > transparency so I hope you can help me finding a solution.
>> >> >>>> >> > I prepared a mosaic with 1 bit Raster. I processed the
>> >> >>>> >> > image
>> >> >>>> >> > files
>> >> >>>> >> > with
>> >> >>>> >> > gdal
>> >> >>>> >> > utilities to transform it in geotiff. Here are the output
>> >> >>>> >> > of
>> >> >>>> >> > gdalinfo:
>> >> >>>> >> > Files: 459020.tiff
>> >> >>>> >> > Size is 11653, 9217
>> >> >>>> >> > UNIT["metre",1,
>> >> >>>> >> > Origin = (1450696.319000000134110,4516874.898998536169529)
>> >> >>>> >> > Metadata:
>> >> >>>> >> > AREA_OR_POINT=Area
>> >> >>>> >> > INTERLEAVE=BAND
>> >> >>>> >> > Corner Coordinates:
>> >> >>>> >> > Upper Left ( 1450696.319, 4516874.899) ( 8d24'55.96"E,
>> >> >>>> >> > 40d48'2.48"N)
>> >> >>>> >> > Lower Left ( 1450696.319, 4511022.104) ( 8d24'57.63"E,
>> >> >>>> >> > 40d44'52.69"N)
>> >> >>>> >> > Upper Right ( 1458095.974, 4516874.899) ( 8d30'11.73"E,
>> >> >>>> >> > 40d48'3.96"N)
>> >> >>>> >> > Lower Right ( 1458095.974, 4511022.104) ( 8d30'13.14"E,
>> >> >>>> >> > 40d44'54.16"N)
>> >> >>>> >> > Center ( 1454396.146, 4513948.501) ( 8d27'34.62"E,
>> >> >>>> >> > 40d46'28.35"N)
>> >> >>>> >> > NoData Value=255
>> >> >>>> >> > NBITS=1
>> >> >>>> >> > 0: 255,255,255,255
>> >> >>>> >> > 1: 0,0,0,255
>> >> >>>> >> > I used the mosaic plugin to load them in geoserver 1.7.2.
>> >> >>>> >> > I
>> >> >>>> >> > can
>> >> >>>> >> > get
>> >> >>>> >> > a
>> >> >>>> >> > map
>> >> >>>> >> > with WMS request but there are some white strips at the
>> >> >>>> >> > borders
>> >> >>>> >> > of
>> >> >>>> >> > each
>> >> >>>> >> > file. Original files have overlapping areas that are
>> >> >>>> >> > white. I
>> >> >>>> >> > would
>> >> >>>> >> > like
>> >> >>>> >> > to
>> >> >>>> >> > set the white pixel to transparent and so eliminate the
>> >> >>>> >> > stripes.
>> >> >>>> >> > I set the OutputTransparentColor field in the config of
>> >> >>>> >> > coverage
>> >> >>>> >> > to
>> >> >>>> >> > #FFFFFF
>> >> >>>> >> > but had no result.
>> >> >>>> >> > I tried to set also the InputTransparentColor filed to
>> >> >>>> >> > #FFFFFF
>> >> >>>> >> > value but
>> >> >>>> >> > I
>> >> >>>> >> > got an exception:
>> >> >>>> >> > 2009-02-06 17:09:16,335 ERROR [geotools.rendering] - -
>> >> >>>> >> > Unable
>> >> >>>> >> > to
>> >> >>>> >> > render
>> >> >>>> >> > RenderedOp for this operation.
>> >> >>>> >> > java.lang.RuntimeException: - Unable to render RenderedOp
>> >> >>>> >> > for
>> >> >>>> >> > this
>> >> >>>> >> > operation.
>> >> >>>> >> > at
>> >> >>>> >> > javax.media.jai.RenderedOp.createInstance(RenderedOp.java:827)
>> >> >>>> >> > at
>> >> >>>> >> > javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
>> >> >>>> >> > at
>> >> >>>> >> > javax.media.jai.RenderedOp.getColorModel(RenderedOp.java:2242)
>> >> >>>> >> > Should I use RasterSymbolizer?
>> >> >>>> >> > Thanks a lot for any hint
>> >> >>>> >> > Stefano Iacovella
>> >> >>>> >> > Create and Deploy Rich Internet Apps outside the browser
>> >> >>>> >> > with
>> >> >>>> >> > Adobe(R)AIR(TM)
>> >> >>>> >> > software. With Adobe AIR, Ajax developers can use existing
>> >> >>>> >> > skills
>> >> >>>> >> > and
>> >> >>>> >> > code
>> >> >>>> >> > to
>> >> >>>> >> > build responsive, highly engaging applications that
>> >> >>>> >> > combine
>> >> >>>> >> > the
>> >> >>>> >> > power of
>> >> >>>> >> > local
>> >> >>>> >> > resources and data with the reach of the web. Download the
>> >> >>>> >> > Adobe
>> >> >>>> >> > AIR SDK
>> >> >>>> >> > and
>> >> >>>> >> > Ajax docs to start building applications
>> >> >>>> >> > today-http://p.sf.net/sfu/adobe-com
>> >> >>>> >> > _______________________________________________
>> >> >>>> >> > Geoserver-users mailing list
>> >> >>>> >> > Geoserver-users@lists.sourceforge.net
>> >> >>>> >> > https://lists.sourceforge.net/lists/listinfo/geoserver-users
>> >> > Create and Deploy Rich Internet Apps outside the browser with
>> >> > Adobe(R)AIR(TM)
>> >> > software. With Adobe AIR, Ajax developers can use existing skills
>> >> > and
>> >> > code
>> >> > to
>> >> > build responsive, highly engaging applications that combine the
>> >> > power
>> >> > of
>> >> > local
>> >> > resources and data with the reach of the web. Download the Adobe
>> >> > AIR
>> >> > SDK
>> >> > and
