[Geoserver-users] 2.5 -> 2.5.1 image mosaic regression
I'm seeing a regression for a netcdf image mosaic layer when upgrading from
2.5 to 2.5.1. Starting from a given zoom level, all tiles simply go black.
There's also a variation where a set of evenly spaced tiles go black, while
others remain normal for a given zoomlevel, and then they all return black at
the next zoom level.
I've been looking for the source now for a while, but haven't been able to
figure it out. Here are some more clues I gathered:
-the changes in gt-imagemosaic do not seem to influence the behavior
-the netcdf layer has 3 bands which are merged using the MergeBehavior.Stack,
a similar single banded mosaic, built from the same source data works fine.
-changing the imageio-ext library version does not seem to affect the issue
I'll continue looking myself, but if this rings a bell somewhere then I'm
certainly interested. I also scanned the diff on github, but there's are not
that many changes to the relevant code.
thanks,
Jeroen
You may wish to create a bug report for this one as it has been a couple of days without a reply. Also gives you a chance to attach screen snaps.
I think we may of upgraded ImageIO extension between 2.5 and 2.5.1.
Jody Garnett
On Thu, Jun 12, 2014 at 7:59 PM, Jeroen Dries <jeroen.dries@anonymised.com> wrote:
I’m seeing a regression for a netcdf image mosaic layer when upgrading from
There’s also a variation where a set of evenly spaced tiles go black, while
I’ve been looking for the source now for a while, but haven’t been able to
I’ll continue looking myself, but if this rings a bell somewhere then I’m
certainly interested. I also scanned the diff on github, but there’s are not
thanks,
Jeroen
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
Hi Jeroen,
sorry for the delay. Could you provide us a sample data for replicating the issue?
Best Regards,
Nicola Lagomarsini.
2014-06-14 10:42 GMT+02:00 Jody Garnett <jody.garnett@anonymised.com>:
Jody
Ing. Nicola Lagomarsini
Junior Software Engineer
Via Poggio alle Viti 1187
Jody Garnett
thanks,
Jeroen
Hi Nicola,
thanks, but the problem is that it's a complex setup, which basically only
runs here internally. I would have to replicate the issue in a setup without
internal dependencies to give you something.
Also screenshots are not going to be very helpful since they are simply black.
I also haven't seen anyone else complaining so I guess it's something very
specific. Perhaps I'll try debugging it a bit more later on.
thanks anyway,
Jeroen
On Tuesday 17 June 2014 15:52:11 Nicola Lagomarsini wrote:
Hi Jeroen,
issue?
Best Regards,
Nicola Lagomarsini.
> Jody
> Jody Garnett
> wrote:
>> Hi all,
>> from
>> black.
>> while
>> black at
>> to
>> fine.
>> issue
>> not
>> thanks,
>> Jeroen
>> ----- HPCC Systems Open Source Big Data Platform from LexisNexis Risk
>> Solutions Find What Matters Most in Your Big Data with HPCC Systems
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
