[Geoserver-users] 2.5 WCS getCoverage
Hi
I am making two WCS getCoverage requests for the same file against geoserver 2.2.4 and geoserver 2.5. When I make a request against 2.2.4 I get a file type with a size of 28MB. When I make a request against 2.5 I get an email type with a size of 420MB. Does anyone have any insight into why I am getting two different types with significantly different sizes?
Here’s the request
…./ geoserver/wcs?SERVICE=WCS&VERSION=1.1.1&REQUEST=GetCoverage&IDENTIFIER=imagery:goes_15.WV.1km&BOUNDINGBOX=-179.9579382,-65.0071874,-105.0020618,65.0071874,urn:ogc:def:crs:OGC:1.3:CRS84&FORMAT=image/tiff
Thanks
Dominique
Hi Dominique,
Just from what’s in your email I’d surmise that there’s an issue with 2.5; you’re clearly requesting an image/tiff type so that’s what you should be getting rather than an “email type”.
What format is the actual output of both versions? Can you run gdal_info past it for both files?
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 9 July 2014 23:56, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
Hi
Here’s the request
Thanks
Dominique
Open source business process management suite built on Java and Eclipse
Turn processes into business applications with Bonita BPM Community Edition
Quickly connect people, data, and systems into organized workflows
Winner of BOSSIE, CODIE, OW2 and Gartner awards
http://p.sf.net/sfu/Bonitasoft
Geoserver-users mailing list
