[Geoserver-users] 2.8 RC1 SEVERE: Error listenerStart
Good morning,
I just ran into a strange situation:
I have been testing 2.8 RC1 on a development server with good results.
I then tried to run it on another server, which has the same Tomcat version and has been running 2.5.5.1 happily for some time.
2.8RC1 refuses to start. Very little information in the log files, just this:
INFO: Starting service Catalina
Oct 1, 2015 1:17:32 AM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.42
Oct 1, 2015 1:17:32 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive E:\OGI\Programs\Tomcat\apache-tomcat-GeoServer\webapps\geoserver.war
Oct 1, 2015 1:17:38 AM org.apache.catalina.core.StandardContext startInternal
Any hints on what to look for?
Roger
Just for completeness, I just tried the 2.8.0 release, and it doesn’t start either.
Thanks for your help,
Roger
On Thu, Oct 1, 2015 at 8:59 AM, Roger Bedell <sylvanascent@anonymised.com> wrote:
Good morning,
Roger
Hi Roger,
there is not enough info in the logs you provided. Suggestion:
  • clean the log file completely
  • restart geoserver, make it fail
  • zip the full log file, share it on the list
On Thu, Oct 1, 2015 at 9:10 AM, Roger Bedell <sylvanascent@anonymised.com> wrote:
Roger
Geoserver-users mailing list
Good morning,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Roger,
I don’t see GeoServer own log, to be found in the data directory, under logs/geoserver.log
That’s the one I was interested into when I described the procedure to gather the full logs :slight_smile:
On Thu, Oct 1, 2015 at 11:07 AM, Roger Bedell <sylvanascent@anonymised.com> wrote:
Hello Andrea,
Here are the logs, but I don’t think you find much more. This is the problem - very little to go on. However, when I put 2.5.5.1 back in the Tomcat Webapps (the same exact place as I tried 2.8.0), it starts up and runs fine.
This got me thinking, why not try the releases since 2.5.5.1?
So, I did the following:
  1. Started the 2.5.5.1 war with no extensions. - this started fine
  2. Same for 2.6.5. Didn’t start, but the log has some details about security.
  3. Same for 2.7.2 Also didn’t start, nothing in the log.
  4. And for 2.8.0, same as 2.7.2
This made me think about the Java version. On the dev server, we have
java version “1.7.0”
Java™ SE Runtime Environment (build 1.7.0-b147)
Java HotSpot™ 64-Bit Server VM (build 21.0-b17, mixed mode)
On the new server, we had JRE-6u43_64bit, but then I upgraded to:
java version “1.8.0_60”
Java™ SE Runtime Environment (build 1.8.0_60-b27)
Java HotSpot™ 64-Bit Server VM (build 25.60-b23, mixed mode)
with the same result, no startup for 1.8.0 or 1.6.5 (logs attached also)
All the logs for each startup are attached.
Roger
On Thu, Oct 1, 2015 at 9:40 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Roger,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Good morning,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Roger,
wait, I’ve seen what I was looking for after all:
java.lang.UnsupportedClassVersionError: org/geoserver/GeoserverInitStartupListener : Unsupported major.minor version 51.0 (unable to load class org.geoserver.GeoserverInitStartupListener)
at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2899)
at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1173)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1681)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1559)
at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:527)
at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:509)
at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:137)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4854)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5434)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:976)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1653)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
So yeah, you cannot use java 6 anymore (GeoServer 2.5 was the last release to support it if memory serves me well),
you need at least java 7, but the above log comes from the logs2-8-0Java8.zip, which makes me believe your tomcat is not really running
on Java 8 after all
On Thu, Oct 1, 2015 at 11:10 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Roger,
Hello Andrea,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Roger,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Good morning,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Hello Andrea,
No GeoServer log was created. Guess it didn’t get that far.
Roger
Hi Roger,
Hello Andrea,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Roger,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Good morning,
Roger
Thanks Andrea,
I thought that Java 8 was being used, but it wasn’t. The Tomcat instance was still pointing to Java 6 in Tomcat7w.exe. I checked the “Use Default”, and then it started working.
Thanks for the help!
Roger
On Thu, Oct 1, 2015 at 11:13 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Roger,
on Java 8 after all
Hi Roger,
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Oct 1, 2015 at 11:07 AM, Roger Bedell <sylvanascent@anonymised.com.84…> wrote:
Hello Andrea,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Roger,
Roger
Ing. Andrea Aime
@geowolf
Technical Lead
Good morning,
Roger
