I was trying out 2.9, but it won’t start up. Is there something I need to be aware of, like a new Java requirement or something?
Roger
Roger
On Sun, May 29, 2016 at 3:44 PM, Roger Bedell <sylvanascent@anonymised.com>
wrote:
I was trying out 2.9, but it won't start up. Is there something I need to
You are not giving us much to go on... what does not work, what's the
environment and java version?
Making guesses, you need for sure Java 8, it's now the minimum requirement.
If it's windows, it's known that RC1 won't start, should be fixed in 2.9.0
final... while not announced,
you can download it from SF already and try it out:
https://sourceforge.net/projects/geoserver/files/GeoServer/2.9.0/
Now, if you also have the native JAI installed in the JDK, then one step
that used to be
optional has become mandatory (new Jetty version, we still haven't figure
out how to setup
the classloading order to avoid it, suggestions/pull requests welcomed btw):
http://docs.geoserver.org/stable/en/user/production/java.html#geoserver-cleanup
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
Yes, that was it, the JRE version. Thanks. I’d like to try out the GeoFence community module, but where do I find it? The community modules are not in the Source Forge area, and I’m not sure I should use the ones in the nightly build area (though I’ll give it a try…)
Best regards,
Roger
On Sun, May 29, 2016 at 4:02 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sun, May 29, 2016 at 3:44 PM, Roger Bedell <sylvanascent@anonymised.com> wrote:
You are not giving us much to go on… what does not work, what’s the environment and java version?
Making guesses, you need for sure Java 8, it’s now the minimum requirement.
If it’s windows, it’s known that RC1 won’t start, should be fixed in 2.9.0 final… while not announced,
Now, if you also have the native JAI installed in the JDK, then one step that used to be
optional has become mandatory (new Jetty version, we still haven’t figure out how to setup
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, May 29, 2016 at 5:14 PM, Roger Bedell <sylvanascent@anonymised.com>
wrote:
Hi Andrea,
Yes, that was it, the JRE version. Thanks. I'd like to try out the
are not in the Source Forge area, and I'm not sure I should use the ones in
the nightly build area (though I'll give it a try...)
Community modules are not available in relases, but only as part of
nigthtly builds.
If you take a 2.9.x build it should work fine with 2.9.0 final (should
being the operative
word, community modules are not as tested as the released ones).
See: http://docs.geoserver.org/latest/en/user/community/index.html
And you can fetch geofence for 2.9.x here:
http://ares.boundlessgeo.com/geoserver/2.9.x/community-latest/
(you'll probably want the integrated version, called
gs-geofence-server.zip, the
other one assumes a stand-alone geofence is running as a stand alone
application
instead)
cheers
Ing. Andrea Aime
@geowolf
Technical Lead
