[Geoserver-users] 2 instance of GS deployed in one tomcat ?
hi all,
Is it possible to deploy 2 instances of geoserver (1.6.4 and 1.7.4 for example) in one tomcat ?
What about memory use ? class loader,....??
do i have to configure some xml files to do that after deployement ?
Thanks
I don't think it would be a problem. Just give the two WAR files different
names and drop them in the webapps folder.
You might have to allocate more memory to the JVM through the -Xmx flag in
Tomcat's startup. You also might need to allocate more PermGen space:
-XX:MaxPermSize=128m or more.
Sébastien Geindre-2 wrote:
hi all,
Thanks
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
View this message in context: http://www.nabble.com/2-instance-of-GS-deployed-in-one-tomcat---tp23411351p23411471.html
Hi Sébastien,
There should be no issues. At opengeo we host the same tomcat with many geoserver intances inside of it. I don't know of any additional requirements other than the recommended options listed here:
http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
I am sure Arne (our sysadmin) will be happy to share any additional insights.
-Justin
Sébastien Geindre wrote:
hi all,
Thanks
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Justin Deoliveira
OpenGeo - http://opengeo.org
2009/5/6 Justin Deoliveira <jdeolive@anonymised.com>
Hi Sébastien,
One thing to watch for is, if you are sharing data directories between different versions, older versions may trash the entries for new features. So if you create a directory dataset in 1.7.x and then go back to 1.6.x everything breaks and you’ll need to recreate the directory datasource in 1.7.x later.
Ian
Ian Turton
http://www.geotools.org
http://pennspace.blogspot.com/
Hi Sébastien,
everything breaks and you'll need to recreate the directory datasource in
1.7.x later.
Ian
As far as I know, we do not have a decree that GeoServer must play nice with other instaces using the same data directory. I definitely recommend against doing this, I can think of more problematic examples like the one you mention. Storage is cheap, make a copy :wink:
Sébastien:
Memory use is up to the JVM to decide, the only thing you have to do is increase -XX:MaxPermSize=128m (maybe 256). Class loading has always worked fine on Tomcat, as far as I could tell. (We've had some issues with JBoss)
Since you can't set multiple data dirs using environment variables, you have to set it in WEB-INF/web.xml
-Arne
Arne Kepp
Expert service straight from the developers
According to my knowledge, there's nothing preventing of using several instances of GeoServer in a single Tomcat. Also you can setup more than one Tomcat in one host. I don't have any experience on doing that in a production environment but in development environment I have. I have two Tomcats, one with 5-10 Geoserver instances, another one with other stuff. I have also run a third Tomcat when testing other products, like portal servers (liferay, Jahia etc.) No problems so far after I configured enough memory. I've been using jsvc script to control Tomcats (included in standard distribution).
I have also used naming system which keeps different versions in order. I rename new Geoserver instance before deploying it, like geoserver.war >> gs174.war. After that I create a symbolic link from geoserver to that gs174. When new version is released, I repeat the same procedure, change the link like geoserver >> gs175 and leave the previous version as it is. That keeps downgrading easy.
- mika -
Arne Kepp kirjoitti:
Hi Sébastien,
1.7.x later.
Ian
Sébastien:
-Arne
