Thanks a lot for clarifying things, now I won't spend too much time on
searching for something that's not possible!
I'll open a Jira request for the byte counting.
Greetings,
Iris
Groeten, Salutations, Greetings,
Dr. Iris Peeters
Geomatics expert
GeoID bvba
Interleuvenlaan 62
B-3001 Leuven
Belgium
Tel. +32 (0)16 39 47 21
Fax. +32 (0)16 39 47 01
www.GeoID.be
www.visitbelgium3d.com
-----Original Message-----
From: David Winslow [mailto:dwinslow@anonymised.com]
Sent: woensdag 2 april 2008 18:28
To: Andrea Aime
Cc: peeters@anonymised.com; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] 3D shapefile
On Wednesday 02 April 2008 12:11:58 Andrea Aime wrote:
Iris Peeters ha scritto:
> Hello,
> As a new Geoserver user, currently using version 1.5.4, I have a few
> questions:
> - Are 3D shapefiles (with x, y, z values) supported?
Nope, geoserver does not support any kind of 3d datasets at the
moment.
One developer tried to add support to it some time ago but it turned
out to be a non trivial exercise.
> All my imported 3D shapefiles (through DataStores-new) are
"flattened".
> Is there a way to include the z-value? Maybe install a newer
version?
Nope, no version supports 3d data.
> - Can I keep track on how many kB are downloaded through my
> Geoserver WFS?
Hum, in GeoServer 1.6.2 there is a filter that is used to gzip
compress data on the fly (provided the client does support gzip
compression). I guess it could be modified to support byte counting
as well, David, what do you think?
Iris, maybe open a request on jira.codehaus.org so that we won't
forget
about this.
Adding byte counting to the gzip filter should be pretty easy. This
would only
count bytes sent in the body of HTTP responses, though; I'm not sure how
tough it would be to count the headers as well. Definitely worth a Jira
request though.
> - How do I create a username/password to connect to the WFS
> server for collecting data?
This you can do only in GeoServer 1.6.x, that has multi user
abilities.
See http://geoserver.org/display/GEOSDOC/5+Security+subsystem
(it is very rough at the moment, hope it does what you need)
!DSPAM:4040,47f3b056115261849620573!
-David
