I have some shp-files which after published through Geoserver seem to be 3D. GML3 Getfeature response shows attribute: srsDimension="3" and gml:posList has z-coordinates (which are all 0.0.). This will break OpenLayers or I guess it does. I noticed that OL 2.13RC is patched against this?
https://github.com/openlayers/openlayers/pull/530
So my question is: Is there any possibilities in Geoserver for preventing 3D published as 3D, can I force it to 2D?
This will do:
<gml:MultiSurface srsDimension="2" srsName="http://www.opengis.net/gml/srs/epsg.xml#3067">
<gml:surfaceMember>
<gml:Polygon srsDimension="2">
<gml:exterior>
<gml:LinearRing srsDimension="2">
<gml:posList>285383.3058645713 6698894.352306922 285425.5159348707 6699017.2593868375 285342.7181416074
This won't:
<gml:MultiSurface srsDimension="3" srsName="http://www.opengis.net/gml/srs/epsg.xml#3067">
<gml:surfaceMember>
<gml:Polygon srsDimension="3">
<gml:exterior>
<gml:LinearRing srsDimension="3">
<gml:posList>288660.33709455427 6704207.924076746 0.0 288681.0786007411 6704265.434737128 0.0
- mika -
against this?
I believe there is no config allowing you to get that.
The situation vs 2D/3D in GeoServer is evolving, right now WFS tries
to preserve the 3rd dimension if present, WMS of course strips it, but
the same stripping code is not available in the WFS case.
To get what you want I guess one would have to add a flag in the GUI
to force data in 2D mode, and then have code in GeoServer to strip
the 3rd dimension while reading the data.
In your case a directly applicable approach is to ogr2ogr the files
forcing them to 2d:
http://www.gdal.org/ogr2ogr.html
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ok,
thanks for your answer Andrea. Have to adjust our shp-production.
- mika -
Andrea Aime kirjoitti 2013-05-21 11:45:
against this?
https://github.com/openlayers/openlayers/pull/530 [1]
forcing them to 2d:
http://www.gdal.org/ogr2ogr.html [2]
Visit http://geoserver.geo-solutions.it [3] for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
http://www.geo-solutions.it [4]
http://twitter.com/geosolutions_it [5]
Links:
[1] https://github.com/openlayers/openlayers/pull/530
[2] http://www.gdal.org/ogr2ogr.html
[3] http://geoserver.geo-solutions.it/
[4] http://www.geo-solutions.it
[5] http://twitter.com/geosolutions_it
