Ciao Erik,
the easiest thing in geoserver would most probably be to:
- create a coverage view that result in a 4 band raster -->
https://docs.geoserver.org/latest/en/user/data/raster/coverageview.html
- create a jiffle style that merges the 3 and uses env vars from the
client to control the merge -->
https://docs.geoserver.org/latest/en/user/styling/sld/extensions/rendering-transform.html#running-map-algebra-on-the-fly-using-jiffle
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Thu, May 30, 2019 at 6:13 PM van Ingen, Erik <e.vaningen@anonymised.com> wrote:
Hi Geoserver user community,
We currently combine 4 rasters into 1 raster, based on weights provided by the user through the browser in a UI. We now do this in a complete custom way, running an R Shiny server, which uses the leaflet client.
I would like to understand better what other possible architectural patterns are, preferably in combination with Geoserver WMS, in order to remain with open standards.
Are the following patterns valid, which one is best and am I missing a pattern?
· Have a leaflet client, requesting 4 rasters from WMS, generating a new raster (applying the weights) in the browser and displaying this through leaflet?
· Make a custom WMS which takes the weights into account through parameters and generates (applying the weights) the raster? Would this custom WMS run in the Geoserver as some kind of plugin or aside Geoserver as a separate webapp?
· Is a pattern with the Javascript library https://github.com/GeoTIFF/geoblaze relevant here?
· Other?
Best,
Erik
Erik van Ingen
Digital Innovation Consultant
Room A012
Information and Communications Technology Division
Via Paolo di Dono 44, 00142 Rome, Italy
Mob. +39 3331311211
www.ifad.org
~~ The information contained in or accompanying this email and any attachment thereto, is intended solely for the use of the stated recipient(s) and may contain information that is confidential and/or privileged. Any dissemination, distribution or copying of this email and any attachment by anyone who is not a stated recipient is strictly prohibited. If you receive this message in error, please notify the sender immediately and delete the message and any attachment from your system without retaining a copy. ~~
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
