Chris,
I believe I did have a jdk installed. I installed jdk1.5.0_10 to be sure and that did not seem to solve my problem. I also do not think that is the problem because I had geoserver 1.3.0 previously installed on the same machine. I did not have any problems with that install. Is there anything else I should check? I am not all that well versed in linux so hopefully I am not making a silly mistake.
Scott
Scott Pezanowski
email: scottpez@anonymised.com
Date: Wed, 10 Jan 2007 12:51:11 -0500
To: scottpez@anonymised.com
CC: brentowens@anonymised.com; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] 404 error JSPCompiler
Do you have a JDK/SDK installed? Unfortunately GeoServer still requires
a JDK, not just the JRE, to compile the JSPs. We may investigate
pre-compiling JSPs, and we’re also looking to replace the GUI, which
would also remove the dependency on JDKs.
Chris
Scott Pezanowski wrote:
Brent,
Thank you for your reply. I entered the url below into my browser and it
looked like proper xml did come up. I also browsed to the following url
for my local geoserver:
http://www.experimental.geovista.psu.edu/geoserver/wms?service=WMS&request=GetCapabilities
This also seemed to respond with proper xml.
Attached is my catalina.out log file.
Scott
Scott Pezanowski
Date: Wed, 10 Jan 2007 09:26:56 -0800
CC: geoserver-users@lists.sourceforge.net
Can you try entering the following url into your browser and see if it
returns an xml response?
http://sigma.openplans.org:8080/geoserver/wms?service=WMS&request=GetCapabilities
Also can you supply us with the full logs so we can take a look? There
might be a small error hidden in it.
Brent Owens
(The Open Planning Project)
I am trying to deploy Geoserver 1.4.0 war on Red Hat Linux/Tomcat 5.
There does not seem to be any error messages in the Tomcat log files
except one about ArcSDE. However, when I go to the geoserver url, I
receive a 404 error - requested resource not available
/geoserver/JSPCompiler.
Has anyone else come across this? Any help would be appreciated.
Scott
Scott Pezanowski email: scottpez@anonymised.com
Join SourceForge.net’s Techsay panel and you’ll get the chance to
share your
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-users mailing list
Geoserver-users@anonymised.comrceforge.net
share your
!DSPAM:1003,45a52811274251971556521!
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
Chris Holmes
http://topp.openplans.org
Hrm. Could you check the tomcat logs? See if there's anything in there? Or is there any more hint of what's going on with the 404 error?
Chris
Chris,
Scott
Scott Pezanowski
email: scottpez@anonymised.com *********************************************
> From: cholmes@anonymised.com
> pre-compiling JSPs, and we're also looking to replace the GUI, which
> Chris
> > Brent,
> > Thanks,
> > Scott
> > Scott Pezanowski
> > > From: brentowens@anonymised.com
> > > Brent Owens
> > > > Hi,
> > > > Thanks,
> > > > Scott
> > > > Join SourceForge.net's Techsay panel and you'll get the chance to
> > share your
> > > > _______________________________________________
> > > > Geoserver-users@lists.sourceforge.net
> > > > https://lists.sourceforge.net/lists/listinfo/geoserver-users
> > share your
> > Join SourceForge.net's Techsay panel and you'll get the chance to share your
> Chris Holmes
!DSPAM:1003,45a5344f288931804284693!
Chris Holmes
