Chris and Brent,
I am not sure exactly what went wrong the first time I deployed geoserver 1.4.0. However, I started over by deleting the geoserver folder and deploying the war file again and things seem to be working fine now. Thanks for your comments.
Scott
Scott Pezanowski
email: scottpez@anonymised.com
Date: Thu, 11 Jan 2007 10:52:42 -0500
To: scottpez@anonymised.com
CC: brentowens@anonymised.com; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] 404 error JSPCompiler
Hrm. Could you check the tomcat logs? See if there’s anything in
there? Or is there any more hint of what’s going on with the 404 error?
Chris
Scott Pezanowski wrote:
Chris,
I believe I did have a jdk installed. I installed jdk1.5.0_10 to be sure
and that did not seem to solve my problem. I also do not think that is
the problem because I had geoserver 1.3.0 previously installed on the
same machine. I did not have any problems with that install. Is there
anything else I should check? I am not all that well versed in linux so
hopefully I am not making a silly mistake.
Scott
Scott Pezanowski
Date: Wed, 10 Jan 2007 12:51:11 -0500
CC: brentowens@anonymised.com84…; geoserver-users@lists.sourceforge.net
Do you have a JDK/SDK installed? Unfortunately GeoServer still requires
a JDK, not just the JRE, to compile the JSPs. We may investigate
pre-compiling JSPs, and we’re also looking to replace the GUI, which
would also remove the dependency on JDKs.
Chris
Brent,
Thank you for your reply. I entered the url below into my browser
and it
looked like proper xml did come up. I also browsed to the following
url
for my local geoserver:
http://www.experimental.geovista.psu.edu/geoserver/wms?service=WMS&request=GetCapabilities
This also seemed to respond with proper xml.
Attached is my catalina.out log file.
Scott
Scott Pezanowski
Date: Wed, 10 Jan 2007 09:26:56 -0800
CC: geoserver-users@anonymised.comforge.net
Can you try entering the following url into your browser and see
if it
returns an xml response?
http://sigma.openplans.org:8080/geoserver/wms?service=WMS&request=GetCapabilities
Also can you supply us with the full logs so we can take a look?
There
might be a small error hidden in it.
Brent Owens
(The Open Planning Project)
I am trying to deploy Geoserver 1.4.0 war on Red Hat
Linux/Tomcat 5.
There does not seem to be any error messages in the Tomcat log
files
except one about ArcSDE. However, when I go to the geoserver url, I
receive a 404 error - requested resource not available
/geoserver/JSPCompiler.
Has anyone else come across this? Any help would be appreciated.
Scott
Scott Pezanowski email: scottpez@anonymised.com
Join SourceForge.net’s Techsay panel and you’ll get the chance to
share your
opinions on IT & business topics through brief surveys - and
earn cash
Geoserver-users mailing list
share your
opinions on IT & business topics through brief surveys - and earn
cash
share your
opinions on IT & business topics through brief surveys - and earn cash
!DSPAM:1003,45a52811274251971556521!
Chris Holmes
http://topp.openplans.org
!DSPAM:1003,45a5344f288931804284693!
Chris Holmes
Interesting.
It could be that there were botched JSPs that had already been compiled in the web-inf/work folder and they were being read instead of being re-compiled. Or perhaps it was with one of the struts files. Either way, I'm glad it is working for you now.
Brent Owens
Chris and Brent,
Scott
Scott Pezanowski email: scottpez@anonymised.com *********************************************
> From: cholmes@anonymised.com
> Hrm. Could you check the tomcat logs? See if there's anything in
> there? Or is there any more hint of what's going on with the 404 error?
> Chris
> > Chris,
> > Thanks,
> > Scott
> > Scott Pezanowski
> > > pre-compiling JSPs, and we're also looking to replace the GUI, which
> > > Chris
> > > > Brent,
> > and it
> > url
> > > > Thanks,
> > > > Scott
> > > > Scott Pezanowski
> > > > > From: brentowens@anonymised.com
> > > > > CC: geoserver-users@lists.sourceforge.net
> > if it
> > There
> > > > > Brent Owens
> > > > > > Hi,
> > Linux/Tomcat 5.
> > files
> > > > > > Thanks,
> > > > > > Scott
> > > > > > Join SourceForge.net's Techsay panel and you'll get the chance to
> > > > share your
> > earn cash
> > > > > > _______________________________________________
> > > > > > Geoserver-users@lists.sourceforge.net
> > > > > > https://lists.sourceforge.net/lists/listinfo/geoserver-users
> > > > share your
> > cash
> > share your
> > > Chris Holmes
> Chris Holmes
