[Geoserver-users] 404 error on startup
A have a problem with first start od geoserver. I've done instalation as it
was writen on geoserver.org but when a want to start server I can't get to
admin panel. IE shows me 404 Error.
0 [main] INFO org.mortbay.log - Logging to
org.slf4j.impl.SimpleLogger@anonymised.com vi
a org.mortbay.log.Slf4jLog
328 [main] WARN org.mortbay.log - Deprecated configuration used for
C:\GeoServer
/webapps
359 [main] INFO org.mortbay.log - jetty-6.1.8
547 [main] ERROR org.mortbay.log - failed
org.mortbay.jetty.webapp.WebAppContext
@e32802{/geoserver,file:/C:/GeoServer/webapps/geoserver/}
java.lang.UnsupportedClassVersionError:
org/geoserver/GeoserverInitStartupListen
er (Unsupported major.minor version 49.0)
        at java.lang.ClassLoader.defineClass0(Native Method)
        at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
        at
java.security.SecureClassLoader.defineClass(SecureClassLoader.java:12
3)
        at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
        at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
        at
org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoade
r.java:366)
        at
r.java:337)
        at
org.mortbay.jetty.handler.ContextHandler.loadClass(ContextHandler.jav
a:1035)
        at
org.mortbay.jetty.webapp.WebXmlConfiguration.initListener(WebXmlConfi
guration.java:629)
        at
org.mortbay.jetty.webapp.WebXmlConfiguration.initWebXmlElement(WebXml
Configuration.java:367)
        at
org.mortbay.jetty.webapp.WebXmlConfiguration.initialize(WebXmlConfigu
ration.java:289)
        at
org.mortbay.jetty.webapp.WebXmlConfiguration.configure(WebXmlConfigur
ation.java:222)
        at
org.mortbay.jetty.webapp.WebXmlConfiguration.configureWebApp(WebXmlCo
nfiguration.java:180)
        at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
a:1217)
        at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
510)
        at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448
        at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
39)
        at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
.java:152)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
dlerCollection.java:156)
        at
39)
        at
.java:152)
        at
39)
        at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
130)
        at org.mortbay.jetty.Server.doStart(Server.java:222)
        at
39)
        at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:324)
        at org.mortbay.start.Main.invokeMain(Main.java:183)
        at org.mortbay.start.Main.start(Main.java:497)
        at org.mortbay.start.Main.main(Main.java:115)
609 [main] ERROR org.mortbay.log - failed ContextHandlerCollection@anonymised.com
        at
3)
        at
r.java:366)
        at
r.java:337)
        at
a:1035)
        at
guration.java:629)
        at
        at
ration.java:289)
        at
ation.java:222)
        at
        at
a:1217)
        at
510)
        at
        at
39)
        at
.java:152)
        at
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
703 [main] INFO org.mortbay.log - Opened
C:\GeoServer\logs\2009_02_07.request.lo
g
703 [main] ERROR org.mortbay.log - failed HandlerCollection@anonymised.com
        at
3)
        at
r.java:366)
        at
r.java:337)
        at
a:1035)
        at
guration.java:629)
        at
        at
ration.java:289)
        at
ation.java:222)
        at
        at
a:1217)
        at
510)
        at
        at
39)
        at
.java:152)
        at
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
781 [main] ERROR org.mortbay.log - Error starting handlers
        at
3)
        at
r.java:366)
        at
r.java:337)
        at
a:1035)
        at
guration.java:629)
        at
        at
ration.java:289)
        at
ation.java:222)
        at
        at
a:1217)
        at
510)
        at
        at
39)
        at
.java:152)
        at
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
937 [main] INFO org.mortbay.log - Started
SelectChannelConnector@anonymised.com:8080
View this message in context: http://www.nabble.com/404-error-on-startup-tp21891771p21891771.html
What version of java are you using? Is it a sun jdk? Also which version of GeoServer?
-Justin
C:\GeoServer
/webapps
        at
3)
        at
r.java:366)
        at
r.java:337)
        at
a:1035)
        at
guration.java:629)
        at
        at
ration.java:289)
        at
ation.java:222)
        at
        at
a:1217)
        at
510)
        at
        at
39)
        at
.java:152)
        at
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
        at
3)
        at
r.java:366)
        at
r.java:337)
        at
a:1035)
        at
guration.java:629)
        at
        at
ration.java:289)
        at
ation.java:222)
        at
        at
a:1217)
        at
510)
        at
        at
39)
        at
.java:152)
        at
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
g
        at
3)
        at
r.java:366)
        at
r.java:337)
        at
a:1035)
        at
guration.java:629)
        at
        at
ration.java:289)
        at
ation.java:222)
        at
        at
a:1217)
        at
510)
        at
        at
39)
        at
.java:152)
        at
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
        at
3)
        at
r.java:366)
        at
r.java:337)
        at
a:1035)
        at
guration.java:629)
        at
        at
ration.java:289)
        at
ation.java:222)
        at
        at
a:1217)
        at
510)
        at
        at
39)
        at
.java:152)
        at
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
Justin Deoliveira
OpenGeo - http://opengeo.org
