[Geoserver-users] 404 when reverting to a previous version
I had version 1.7.3 of geoserver installed and I uninstalled it and
installed version 2.0-alpha2 to see if an issue had been fixed in that
version. It haddn't, so I uninstalled it and re-installed version 1.7.3.
However I am now getting a 404 error message when I attempt to access the
admin pages (http://localhost:8080/geoserver/web). I read on these forums
that deleting the C:\Documents and Settings\<username>\Local
Settings\Temp\Geotools folder can fix this but it didn't work. Here is the
startup log:
D:\GeoServer1.7.3\bin>startup
16 [main] INFO org.mortbay.log - Logging to
org.slf4j.impl.SimpleLogger@anonymised.com v
ia org.mortbay.log.Slf4jLog
219 [main] WARN org.mortbay.log - Deprecated configuration used for
D:\GeoServer
1.7.3/webapps
235 [main] INFO org.mortbay.log - jetty-6.1.8
log4j:WARN File option not set for appender [logfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
1313 [main] INFO /geoserver - Initializing Spring root WebApplicationContext
17 Apr 12:22:03 INFO [context.ContextLoader] - Root WebApplicationContext:
initi
alization started
log4j:ERROR No output stream or file set for the appender named [logfile].
17 Apr 12:22:03 INFO [support.XmlWebApplicationContext] - Refreshing
org.springf
ramework.web.context.support.XmlWebApplicationContext@anonymised.com: display name
[Roo
t WebApplicationContext]; startup date [Fri Apr 17 12:22:03 BST 2009]; root
of c
ontext hierarchy
17 Apr 12:22:03 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean
definition
s from URL
[file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/classes/applicatio
nContext.xml]
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/gwc-1.7.3.
jar!/applicationContext.xml]
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/main-1.7.3
.jar!/applicationContext.xml]
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/rest-1.7.3
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/validation
-1.7.3.jar!/applicationContext.xml]
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/wcs-1.7.3.
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/wcs1_1-1.7
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/wfs-1.7.3.
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/wfs11-1.7.
definition
s from URL
[jar:file:/D:/GeoServer1.7.3/webapps/geoserver/WEB-INF/lib/wms-1.7.3.
definition
s from URL
nSecurityContext.xml]
definition
s from URL
.jar!/applicationSecurityContext.xml]
17 Apr 12:22:03 INFO [support.XmlWebApplicationContext] - Bean factory for
appli
cation context
[org.springframework.web.context.support.XmlWebApplicationContext
@1202d69]:
org.springframework.beans.factory.support.DefaultListableBeanFactory@
df48c4
17 Apr 12:22:04 INFO [support.XmlWebApplicationContext] - Bean
'resourceLoader'
is not eligible for getting processed by all BeanPostProcessors (for
example: no
t eligible for auto-proxying)
17 Apr 12:22:04 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: d:\GeoServer1.7.3\data_dir
17 Apr 12:22:04 INFO [support.DefaultListableBeanFactory] -
Pre-instantiating si
ngletons in
@df48c4: defining beans
[applicationState,applicationStateRegisterar,dispatcherM
apping,gwcAppCtx,gwcXmlConfig,gwcGSConfig,gwcTLDispatcher,gwcDefaultStorageFinde
r,gwcMetaStore,gwcBlobStore,gwcStorageBroker,geowebcacheDispatcher,gwcServiceWMS
,gwcServiceGMaps,gwcServiceMGMaps,gwcServiceVE,gwcServiceKML,gwcServiceWFS,gwcSe
ederThreadPoolExec,gwcSeedRestlet,gwcSeedFormRestlet,gwcReloadRestlet,gwcTileLay
erRestlet,gwcRestDispatcher,gwcProxyDispatcher,gwcUrlMapping,resourceLoader,exte
nsions,rawCatalog,secureCatalog,geoServer2,geoServerLoader,config,geoServer,glob
alConfig,data,rawData,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfi
gRegisterar,geoServerRegisterar,serviceStrategyFactory,speedServiceStrategy,file
ServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditor
Configurer,dispatcher,filePublisher,jaiInitializer,defaultDataSecurityFactory,de
faultCatalogSecurityFactory,disabledServiceChecker,restWrapper,restletDispatcher
Mapping,validation,validationConfig,validationRegisterar,validationConfigRegiste
rar,wcsLoader,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService
,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,wcsService2,wc
sServiceDescriptor,wcsExceptionHandler,wcsGetCapabilitiesKvpReader,describeCover
ageKvpReader,getCoverageKvpReader,wcsXmlReader,wcsGetCapabilitiesXmlReader,descr
ibeCoverageXmlReader,getCoverageXmlReader,wcsGetCapabilitiesResponse,describeCov
erageResponse,getCoverageResponse,wcsURLMapping,wcs111ServiceTarget,wcsLogger,wc
s111Service,wcsService-1.1.0,wcsService-1.1.1,wcs111URLMapping,wcs111ExceptionHa
ndler,ows11AcceptVersionsKvpParser,ows11SectionsKvpParser,wcs111RangeSubsetKvpPa
rser,wcs111IdentifierKvpParser,wcs111BoundingBoxKvpParser,wcs111GridBaseCRSKvpPa
rser,wcs111TimeSequenceKvpParser,wcs111GridTypeKvpParser,wcs111GridCSKvpParser,w
cs111GridOriginKvpParser,wcs111GridOffsetsKvpParser,wcs111GetCapabilitiesKvpRead
er,wcs111DescribeCoverageKvpReader,wcs111GetCoverageRequestReader,wcs111StoreKvp
Parser,wcs-1.1.1-configuration,wcs111CapabilitiesRequestReader,wcs111DescribeCov
erageRequestReader,wcs111GetCoverageRequestXMLReader,wcs111GetCapabilitiesRespon
se,wcs111DescribeCoverageResponse,wcs111GetCoverageMultipartResponse,wcs111GetCo
verageStoreResponse,wcs111DispatcherMapping,wcs111TempStorageCleaner,wcs111TempS
torageCleanerTask,wcs111timerFactory,wfsConfig,wfsRegisterar,wfsConfigRegisterar
,filterFactory,wfsLoader,wfs,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElem
entHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandl
er,wfsService-1.0.0,wfsExceptionHandler,gml2SchemaBuilder,wfsXsd-1.0,xmlConfigur
ation-1.0,getCapabilitiesResponse,lockFeatureResponse-1.0,transactionResponse-1.
0,geometryResponse,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdK
vpParser,bboxKvpParser,filterKvpParser,cqlKvpParser,propertyNameKvpParser,maxFea
tureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpPars
er,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsFormatOptio
nsKvpParser,charsetKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpR
eader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,trans
actionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader
,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,loc
kFeatureXmlReader,transactionXmlReader,gml2FeatureTypeEncoder,gml2OutputFormat,s
hapezipOutputFormat,geojsonOutputFormat,CSVOutputFormat,wfsService-1.1.0,wfsExce
ptionHandler-1.1,wfsXsd-1.1,xmlConfiguration-1.1,gml3SchemaBuilder,xmlReader-1.1
.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatu
reTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1
.0,transactionXmlReader-1.1.0,getGmlObjectXmlReader-1.1.0,gml3FeatureTypeEncoder
,gml3OutputFormat,hitsOutputFormat,lockFeatureResponse-1.1,transactionResponse-1
.1,featureResponse,wmsLoader,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wms
AbstractService,wmsService,wmsGetCapabilities,wmsDescribeLayer,wmsGetFeatureInfo
,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsService2,wmsServiceDescriptor,
wmsExceptionHandler,widthKvpParser,heightKvpParser,wmsFormatOptionsKvpParser,bgC
olorKvpParser,transparentKvpParser,tiledKvpParser,tilesOriginKvpParser,bufferKvp
Parser,paletteKvpParser,timeKvpParser,elevationKvpParser,validateSldKvpParser,sl
dKvpParser,startIndexKvpParser,wmsGetCapabilitiesKvpReader,describeLayerKvpReade
r,getMapKvpReader,getFeatureInfoKvpReader,getLegendGraphicKvpReader,wmsCapabilit
iesXmlReader,getMapXmlReader,sldXmlReader,wmsGetCapabilitiesResponse,describeLay
erResponse,getMapResponse,getFeatureInfoResponse,getLegendGraphicResponse,putSty
lesWrapper,wmsURLMapping,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLe
gendProducerFactory,PNGMapProducer,GeoTiffMapProducer,TiffMapProducer,GIFMapProd
ucer,JPEGMapProducer,PDFMapProducerFactory,KMLMapProducer,KMZMapProducer,OpenLay
ersMapProducer,AtomGeoRSSMapProducer,RSSGeoRSSMapProducer,SVGMapProducer,kmlServ
ice,kmlServiceDescriptor,kmlURLMapping,superOverlayKvpParser,legendKvpParser,kma
trrKvpParser,kmscoreKvpParser,kmplacemarkKvpParser,metaTileCache,nativeSortingRe
gionator,externalSortingRegionator,geometryRegionator,randomRegionator,bestGuess
Regionator,filterChainProxy,restFilterInvocationInterceptor,restFilterDefinition
Map,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,h
ttpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProces
singFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,an
onymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,co
nsoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices
,authenticationManager,daoAuthenticationProvider,userDetailsService,operationSec
urityInterceptor]; root of factory hierarchy
log4j:WARN File option not set for appender [geoserverlogfile].
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded namespace
'it.geosolutions' (h
ttp://www.geo-solutions.it)
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded namespace 'cite'
(http://www.o
pengeospatial.net/cite)
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded namespace 'tiger'
(http://www.
census.gov)
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded namespace 'sde'
(http://geoser
ver.sf.net)
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded namespace 'topp'
(http://www.o
penplans.org/topp)
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded namespace 'sf'
(http://www.ope
nplans.org/spearfish)
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded namespace 'nurc'
(http://www.n
urc.nato.int)
17 Apr 12:22:04 INFO [geoserver.catalog] - Default namespace: 'topp'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'capitals'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'simple_roads'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'grass'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'green'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'cite_lakes'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'restricted'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'giant_polygon'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'pophatch'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'simple_streams'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'line'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'poi'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'polygon'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'raster'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'point'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'tiger_roads'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'burg'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'poly_landmarks'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'dem'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'rain'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded style 'population'
17 Apr 12:22:04 INFO [geoserver.catalog] - Processed data store
'taz_shapes', en
abled
17 Apr 12:22:04 INFO [geoserver.catalog] - Processed data store 'sf',
enabled
17 Apr 12:22:04 INFO [geoserver.catalog] - Processed data store 'nyc',
enabled
'states_shapefil
e', enabled
17 Apr 12:22:04 INFO [geoserver.catalog] - Processed coverage store 'sfdem',
ena
bled
'arcGridSamp
le', enabled
'mosaic', en
abled
'img_sample2
', enabled
'worldImageS
ample', enabled
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded feature type
'tiger:giant_poly
gon'
17 Apr 12:22:04 INFO [geoserver.catalog] - Loaded feature type 'tiger:poi'
'tiger:poly_landm
arks'
'tiger:tiger_road
s'
17 Apr 12:22:05 INFO [geoserver.catalog] - Loaded feature type
'sf:archsites'
17 Apr 12:22:05 INFO [geoserver.catalog] - Loaded feature type 'sf:bugsites'
'sf:restricted'
17 Apr 12:22:05 INFO [geoserver.catalog] - Loaded feature type 'sf:roads'
17 Apr 12:22:05 INFO [geoserver.catalog] - Loaded feature type 'sf:streams'
17 Apr 12:22:05 INFO [geoserver.catalog] - Loaded feature type 'topp:states'
'topp:tasmania_ci
ties'
'topp:tasmania_ro
ads'
'topp:tasmania_st
ate_boundaries'
'topp:tasmania_wa
ter_bodies'
17 Apr 12:22:22 WARN [referencing.factory] - Axis elements found in a wkt
defini
tion, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["W
GS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
UNIT["degree", 0
.017453292519943295]], PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of
_origin", 0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.
0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0],
UNIT["m",
1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
17 Apr 12:22:22 WARN [geoserver.catalog] - Ignoring coverage: 'sfDem_dem',
cover
age store 'sfDem' not found
17 Apr 12:22:22 INFO [geoserver.confg] - Loading service 'wcs'
17 Apr 12:22:22 INFO [geoserver.confg] - Loading service 'wfs'
17 Apr 12:22:22 INFO [geoserver.wms] - Processed layer group 'tiger-ny'
17 Apr 12:22:22 INFO [geoserver.wms] - Processed layer group 'tasmania'
17 Apr 12:22:22 INFO [geoserver.wms] - Processed layer group 'spearfish'
17 Apr 12:22:22 INFO [geoserver.confg] - Loading service 'wms'
17 Apr 12:22:23 INFO [util.ApplicationContextProvider] - No context
parameter, s
ystem or Java environment variables found for GEOSERVER_WMS_URL
17 Apr 12:22:23 INFO [util.ApplicationContextProvider] - Reverting to
http://loc
alhost:8080/geoserver/wms?request=GetCapabilities
17 Apr 12:22:23 INFO [util.GetCapabilitiesConfiguration] - Constructing from
url
http://localhost:8080/geoserver/wms?request=GetCapabilities
17 Apr 12:22:23 INFO [storage.DefaultStorageFinder] - Found Servlet context
para
meter GEOSERVER_DATA_DIR set to d:\GeoServer1.7.3\data_dir, using it as the
defa
ult prefix.
17 Apr 12:22:23 INFO [geowebcache.GeoWebCacheDispatcher] - set
TileLayerDispatch
er
17 Apr 12:22:23 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked
setServletPre
fix(gwc)
17 Apr 12:22:23 INFO [wms.WMSService] - Will proxy requests to backend that
are
not getmap or getcapabilities.
parameter, s
ystem or Java environment variables found for GEOSERVER_WFS_URL
17 Apr 12:22:23 INFO [util.ApplicationContextProvider] - Reverting to null
parameter, s
ystem or Java environment variables found for GEOWEBCACHE_WFS_FILTER
17 Apr 12:22:23 INFO [wfs.WFSService] - Configured to forward to
http://localhos
t:8080/geoserver/wfs , timeout is 600000ms, regex filter null
17 Apr 12:22:23 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 4
paths
17 Apr 12:22:24 WARN [geoserver.securit] - Rule *.*.r=* is overriding
another ru
le targetting the same resource
17 Apr 12:22:24 WARN [geoserver.securit] - Rule *.*.w=* is overriding
another ru
22610 [main] INFO /geoserver - Initializing WebApplicationContext for Struts
Act
ionServlet 'action', module ''
22625 [main] INFO org.mortbay.log - Opened
D:\GeoServer1.7.3\logs\2009_04_17.req
uest.log
22797 [main] INFO org.mortbay.log - Started
SelectChannelConnector@anonymised.com:8080
Can anyone let me know where im going wrong?
Thanks
View this message in context: http://www.nabble.com/404-when-reverting-to-a-previous-version-tp23095759p23095759.html
http://localhost:8080/geoserver/web is an artifact of the new UI and indeed only valid in 2.x
If you instead go to http://localhost:8080/geoserver you should be automatically redirected to http://localhost:8080/geoserver/welcome\.do , which is the equivalent path in 1.7.x
-Arne
dk80 wrote:
startup log:
<snip>
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
