[Geoserver-users] 500 error on REST layer and store delete
Hello list,
in the GeoNode project we recently upgraded the geoserver version to 2.4, which is great, although we are facing an issue related to the REST layer delete.
The issue is described here https://github.com/GeoNode/geonode/issues/1284 and the piece of code originating it is here https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/helpers.py#L218.
The workflow we use to delete a layer is:
  • Delete the layer
  • Delete the associated styles
  • Delete the featuretype
  • Delete the store
We get a 500 error (the stacktrace is in the issue) on the delete featuretype step.
The http request we make is a DELETE to an address like this one http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/streams/featuretypes/streams.xml
Which exists before the call and doesn’t exist anymore after the call even if the result is a 500 error.
Thanks i advance for any help and suggestion you can give
Simone
On Thu, Nov 28, 2013 at 10:17 AM, Simone Dalmasso <simone.dalmasso@anonymised.com
wrote:
Hello list,
delete.
- Delete the layer
- Delete the associated styles
- Delete the featuretype
- Delete the store
featuretype step.
Which exists before the call and doesn't exist anymore after the call even
Is GeoServer logging any strack trace when this happens?
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea, yes this is the stack
http://pastebin.com/ZUX8ceFE
2013/11/28 Andrea Aime <andrea.aime@anonymised.com>
Simone
On Thu, Nov 28, 2013 at 10:17 AM, Simone Dalmasso <simone.dalmasso@anonymised.com> wrote:
Hello list,
  • Delete the layer
  • Delete the store
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Nov 28, 2013 at 10:29 AM, Simone Dalmasso <simone.dalmasso@anonymised.com
That is useful. Can you open a ticket at
http://jira.codehaus.org/browse/GEOS, adding that stack trace,
and a description of how to reproduce, in it?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Sure,
thanks!
Simone
On Thu, Nov 28, 2013 at 10:29 AM, Simone Dalmasso <simone.dalmasso@anonymised.com> wrote:
That is useful. Can you open a ticket at http://jira.codehaus.org/browse/GEOS, adding that stack trace,
Ing. Andrea Aime
@geowolf
Technical Lead
In the meantime do you have any suggestions?
Doing some tests I noticed that in order to preserve the geoserver integrity I can add a try block around that DELETE call and then trigger a geoserver catalog reload. Without the reload the reload of the same layer breaks and there are other errors.
Chhers
2013/11/28 Simone Dalmasso <simone.dalmasso@anonymised.com>
Sure,
thanks!
Simone
Simone
Ing. Andrea Aime
@geowolf
Technical Lead
