[Geoserver-users] 900913
Could somebody point me to the correct definition for the google maps
projection (epsg 90013)?
And I guess I need to add it to both the epsg.properties file and also to
the spatial_ref_sys table in postgis?
Steve
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
It now has an official code: EPSG:3785
http://www.iter.dk/post/2008/05/SphericalWeb-Mercator-EPSG-code-3785.aspx
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
Steve
Stephen Crawford
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
Steve,
in proj its this:
#Google Mercator projection
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs
Regards, Till
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams@anonymised.com http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
And that link has the full definition from EPSG:
Full WKT with authorities (untested!):
PROJCS["Popular Visualisation CRS / Mercator", GEOGCS["Popular Visualisation CRS", DATUM["Popular Visualisation Datum", SPHEROID["Popular Visualisation Sphere", 6378137, 0, AUTHORITY["EPSG",7059]], TOWGS84[0, 0, 0, 0, 0, 0, 0], AUTHORITY["EPSG",6055]], PRIMEM["Greenwich", 0, AUTHORITY["EPSG", "8901"]], UNIT["degree", 0.0174532925199433, AUTHORITY["EPSG", "9102"]], AXIS["E", EAST], AXIS["N", NORTH], AUTHORITY["EPSG",4055]], PROJECTION["Mercator"], PARAMETER["False_Easting", 0], PARAMETER["False_Northing", 0], PARAMETER["Central_Meridian", 0], PARAMETER["Latitude_of_origin", 0], UNIT["metre", 1, AUTHORITY["EPSG", "9001"]], AXIS["East", EAST], AXIS["North", NORTH], AUTHORITY["EPSG",3785]]
Projected CRS
COORD_REF_SYS_CODE: 3785
COORD_REF_SYS_NAME: Popular Visualisation CRS / Mercator
AREA_OF_USE_CODE: 3544
COORD_REF_SYS_KIND: projected
COORD_SYS_CODE: 4499
DATUM_CODE:
SOURCE_GEOGCRS_CODE: 4055 (see below)
PROJECTION_CONV_CODE: 19847
CMPD_HORIZCRS_CODE:
CMPD_VERTCRS_CODE:
CRS_SCOPE: Certain Web mapping and visualisation applications.
REMARKS: Uses spherical development. Relative to an ellipsoidal development errors of up to 800 metres in position and 0.7% in scale may arise. Some applications call this WGS 84. It is not a recognised geodetic system: see WGS 84 / World Mercator (CRS code 3395)
INFORMATION_SOURCE: Microsoft.
DATA_SOURCE: OGP
REVISION_DATE: 3/14/2008
CHANGE_ID:
SHOW_CRS: TRUE
DEPRECATED: FALSE
Geographic CRS:
COORD_REF_SYS_CODE: 4055
AREA_OF_USE_CODE: 31262
COORD_REF_SYS_KIND: geographic 2D
COORD_SYS_CODE: 6422
DATUM_CODE: 6055 (see below)
CMPD_HORIZCRS_CODE:
CMPD_VERTCRS_CODE:
REMARKS: Some applications erroneously call this WGS 84. It uses a sphere with a radius having the same value as the semi-major axis of the WGS 84 ellipsoid. There is no geodetic recognition of this system.
DATA_SOURCE: OGP
REVISION_DATE: 3/13/2008
CHANGE_ID:
SHOW_CRS: TRUE
DATUM_CODE: FALSE
Datum:
Code: 6055
Datum Name: Popular Visualisation
Datum Type: geodetic
Origin Description: Not specified in the classical sense of defining a geodetic datum.
Datum Epoch:
Ellipsoid Code: 7059 (see below)
Prime Meridian Code: 8901
Area Code: 1262
Datum Scope : Used by certain popular Web mapping and visualisation applications.
Remarks: Not recognised by geodetic authorities.
Information Source: Microsoft.
Data Source: OGP
Revision Date: 13-Mar-08
Change ID:
Deprecated: No
Ellipsoid:
Code: 7059
Ellipsoid Name: Popular Visualisation Sphere
Semi-major axis (a): 6378137
Axes units code: 9001
Inverse flattening (1/f):
Semi-minor axis (b): 6378137
Ellipsoid?: No
Remarks: Sphere with radius equal to the semi-major axis of the GRS80 and WGS 84 ellipsoids. Used only for Web approximate mapping and visualisation. Not recognised by geodetic authorities.
Data Source: OGP
Revision Date: 14-Mar-08
Change ID:
Deprecated?: No
Others have linked to the official EPSG code but I still haven't tried
it out and I don't know if it's correctly handled by the GeoTools
referencing subsystem.
The following is the one we're shipping along with GeoServer (paste
it all in one line inside your epsg.properties file):
900913=PROJCS["WGS84 / Google Mercator", GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AUTHORITY["EPSG","4326"]], PROJECTION["Mercator (1SP)", AUTHORITY["EPSG","9804"]], PARAMETER["semi_major", 6378137.0], PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AUTHORITY["EPSG","900913"]]
