Folks,
it may be just me, but whenever I change something in a database (adding/dropping a table, etc.) I have to restart GeoServer to actually see those changes in the admin interface.
I understand the refresh of every FeatureStore is timec-onsuming, but what about a "refresh FeatureStores" button ?
Luca Morandini
www.lucamorandini.it
Have you tried hitting 'load'?
That usually refreshes most things, from the last changed state.
Chris
Luca Morandini wrote:
Folks,
Luca Morandini
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
!DSPAM:1003,4523549717191665516417!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Apparently, it doesn't refreshes the datastore (my configuration: DB2 8.2 with Spatial Extenter, JDK 1.5.0, WebLogic 9.2, GeoServer WCS branch).
Luca Morandini
Hi Luca:
Hitting "Load" will refresh the catalog. However, if you delete Oracle
tables that you configured as FeatureTypes in geoserver, you will also
need to delete their configuration (info.xml) in geoserver, and then
reload the catalog.
Alex
Luca Morandini
Alexander Petkov wrote:
Hi Luca:
reload the catalog.
Alex, I meant something different: say you add a new spatial-enabled table to your DBMS: I'd like to see that table in the list of available DataStore.
Luca Morandini
Are your spatially-enabled tables added/deleted in some sort of automated way?
Alex
> Hi Luca:
> reload the catalog.
DataStore.
Luca Morandini
No, it's a DB2 command, akin to shp2sdo in Oracle.
Reagrds,
Luca Morandini
Luca, adding feature types is a manual operation in the UI. What you're proposing is a special case
of ingestion engine afaik, that is, a tool that periodically looks up files and dbms and imports automatically
new feature types... we don't have one at the moment, yet I understand it may be interesting for people
that have lots of data sources, eventually daily or hourly created from other sources.
For the moment I guess you'll have to write some code for your own scheduled taks that adds the new
feature types to the configuration...
No, no, I didn't mean that.
I'd just want GeoServer to refresh the list of tables shown in the "Create New FeatureType" page at the press of a button.
Luca Morandini
Luca:
I thought Geoserver does that, at least with a Postgis datastore.
Alex
