[Geoserver-users] About arcsde plugin error!
Hello!
I'm trying geoserver. I have tried last 3 versions, but none of them connected
to arcsde. By the first I couldn't get that plugin to work (show ArcSde in
dropdown list). Now it is in the drop down list, but I can't connect to
ArcSDE.
I thin I have followed that manual in
http://docs.codehaus.org/display/GEOTDOC/ArcSDE+DataStore but anyway it doesn't
work. Every time I try it returns me the error Invalid URLfor format
type:'ArcSDE Raster'.
I hope you could help me to get it work. By the way a link to an tif raster file
works fine.
Uldis Gitendorfs
TVNET - Zinu adresse :: http://www.tvnet.lv
goodness@anonymised.com ha scritto:
Hello!
ArcSDE.
As far as I know, support for rasters embedded in ArcSDE is quite limited. I've never tried it out, but I remember other discussions
about this an you should be aware that you first need to setup
a ArcSDE vector datastore, and only after try to use a raster connection
(because that will try and use the same set of SDE connections).
After that, I know only certain image types are supported, but I
don't know of a list.
I'm trying to cc the developer that created the raster support,
he should know more.
