My Qurey is that I have 4 layers in my map and I want to reload only one
layer without reloading other 3 layers.
I just want to relaod only one layer at the time of reloading the map. is it
possible to do tht, if yes please let me know the steps and files to be
changed for that.
I have one more Query about Zoom in and Zoom out.
After reloading the map these functions are not working, wht could me the
error for that?
Your question concerns more the application you are using than Geoserver that stands there behind. Geoserver will send back exactly as many layers as the application is demanding in the request it sends. It is up to the application if it can do that or if it is reasonable (can the application cache the other layers etc.). You should give more information about the application. If there exists a mailing list for the users of that application then it might give you better help.
-Jukka Rahkonen-
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net puolesta: Bobby
Lähetetty: pe 9.3.2007 7:20
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] About reloading only one layerin Geo Server
HI to all,
changed for that.
error for that?
