Hi.
I did install the plugin csw on my geoserver.
I’d like to limit csw responses to features enabled on geoserver to logged user.
Is it posible?
TIA
jorge infante
rosario - santa fe - argentina
Hi.
Is it posible?
TIA
jorge infante
On Mon, May 2, 2016 at 1:20 PM, Jorge Infante <joluinfante@anonymised.com> wrote:
Hi.
I'd like to limit csw responses to features enabled on geoserver to logged
user.
Is it posible?
You mean, to layers enabled in GeoServer the logged user?
If so, that should be the default behavior (I have not tried personally
though, mind),
at least with the catalog set in "HIDE" mode.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi.
Thanks for your response.
If I use the web application to access to geoserver, this works ok. The user not enable to see a layer can’t see it. I have the setting “Catalog mode=hide”.
But, if I try to access from a python script (from a client), I can see the title of layer.
I’m logging to geoserver with:
r=sess.post(“http://”+ip+“:8080/geoserver/j_spring_security_check”, data={‘username’: user, ‘password’: pwd})
I’m trying to access to layers with:
r=sess.post(“http://”+ip+“:8080/geoserver/csw?service=csw&version=2.0.2&request=GetDomain&propertyName=Title”, data={‘username’: user, ‘password’: pwd})
I’m receiving the title of all layers.
2016-05-02 8:46 GMT-03:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi.
Is it posible?
If so, that should be the default behavior (I have not tried personally though, mind),
at least with the catalog set in “HIDE” mode.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Jorge,
not sure what’s going on there (I did not work on the csw/internal catalog integration myself, not sure how it works).
Might be worth opening a bug report, best if you can provide instructions to reproduce using
the default data directory and curl requests on the command line
On Mon, May 2, 2016 at 1:57 PM, Jorge Infante <joluinfante@anonymised.com> wrote:
Hi.
Thanks for your response.If I use the web application to access to geoserver, this works ok. The user not enable to see a layer can’t see it. I have the setting “Catalog mode=hide”.
But, if I try to access from a python script (from a client), I can see the title of layer.I’m logging to geoserver with:
r=sess.post(“http://”+ip+“:8080/geoserver/j_spring_security_check”, data={‘username’: user, ‘password’: pwd})I’m trying to access to layers with:
r=sess.post(“http://”+ip+“:8080/geoserver/csw?service=csw&version=2.0.2&request=GetDomain&propertyName=Title”, data={‘username’: user, ‘password’: pwd})I’m receiving the title of all layers.
Hi.
Is it posible?
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ok. Thanks for your response.
I did check the source, I’m not sure if csw extension is seeing internal store to get me the information.
In http://docs.geoserver.org/2.8.x/en/user/extensions/csw/features.html, I see “set the Java system property DefaultCatalogStore
to make sure that the correct catalog store will be used”. I did put -DDefaultCatalogStore=org.geoserver.csw.store.internal.GeoServerInternalCatalogStore in the startup.sh script, and, It’s not working. I’m thinking the csw extension are using the simple catalog.
Another question: I’m using the internal csw extension of geoserver, but, I did see the GeoNetwork product to process csw request, connected to GeoServer. What is the must appropiate component to listen csw request? I’m trying to use a centralized administration of layers (I’m using ldap integration to doit).
TIA
jorge infante
2016-05-02 9:06 GMT-03:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Jorge,
not sure what’s going on there (I did not work on the csw/internal catalog integration myself, not sure how it works).Might be worth opening a bug report, best if you can provide instructions to reproduce using
the default data directory and curl requests on the command lineCheers
Hi.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi.
Is it posible?
Ing. Andrea Aime
@geowolf
Technical Lead
