[Geoserver-users] Access to HttpServletRequest in FeatureReader
I’m just getting started with a custom data store, packaged and deployed to a GeoServer instance. So far, so good.
However, I need to access the HttpServletRequest to get the client PKI certificate (and likely some other attributes), and I’m not seeing any way to access them in my DataStore or FeatureReader. Any tips here? If not something that can be directly sent, perhaps overriding some REST endpoint and bind the request to a ThreadLocal? Just speculating…
Related, is there any way to override the tile caching strategy so that it only applies it on a per-user basis?
Thanks in advance.
On Wed, May 18, 2016 at 5:05 AM, Shahak Nagiel <snagiel@anonymised.com> wrote:
I'm just getting started with a custom data store, packaged and deployed
certificate (and likely some other attributes), and I'm not seeing any way
and bind the request to a ThreadLocal? Just speculating...
Look at Dispatcher.REQUEST, it's a thread local
Not that I know of, in general that would create a different tile cache per
user, causing the generation of an uncontrolled
number of caches... unless you can categorize your users somehow to keep
the number of caches small.
I don't think anything can be done with the standard GWC classes, but I've
seen applications of user categorization
by rolling a custom tile layer class.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
