[Geoserver-users] Activate layer by zoom - SLD
Hi people,
I'm very very new to SLD (just read some documentation so far) and now I
need to create a SLD that activate and deactivate a layer according to the
zoom level.
I have a layer (points) with more than 18.000 points just in a small area
(around 20 km wide).
Could you give some examples or links, please?
Thank you in advance!
View this message in context: http://old.nabble.com/Activate-layer-by-zoom---SLD-tp28903447p28903447.html
You can show and hide faetures in side the layer according to scales.
Did you try using Scale Denomiators?
you might find your answer here ..scroll down to the zoom based point part
http://docs.geoserver.org/stable/en/user/styling/sld-cookbook/points.html
regards,
Imran
On Wed, Jun 16, 2010 at 7:23 PM, giraam <sdjbm17@anonymised.com> wrote:
Hi people,
zoom level.
ThinkGeek and WIRED's GeekDad team up for the Ultimate
GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
lucky parental unit. See the prize list and enter to win:
http://p.sf.net/sfu/thinkgeek-promo
Geoserver-users mailing list
I.R
Thanks for your reply! I found that solution too but I have a little doubt
about it.. The example shows how to change the <PointSymbolizer> according
to the zoom level but would I be able to deactivate and activate layers just
like that? I mean, I trying to NOT make a request to the server when I do
not need the points at certain zoom level in order to have a faster response
and obviously a relevant information too!
I'm still thinking about SLD as a CSS file and maybe I'm wrong!
Thanks again..!
Imran_Rajjad wrote:
regards,
Imran
I.R
View this message in context: http://old.nabble.com/Activate-layer-by-zoom---SLD-tp28903447p28903773.html
That is the clients responsibility - there is no way GeoServer can
work out that you shouldn't make a request to it depending on your
style.
You will need to ask this question on the user list of whatever client
you are using.
Ian
Ian Turton
Thinking better you are totally right!!
I'll ask on OpenLayers users forum! Thanks you all for your answers!
style.
you are using.
Ian
Ian Turton
View this message in context: http://old.nabble.com/Activate-layer-by-zoom---SLD-tp28903447p28904004.html
If you’r working with openlayers you may want familiarise youself with the API doco…
http://dev.openlayers.org/docs/files/OpenLayers/Layer-js.html
i believe you want the maxResolution / maxScale properties on your layer object.
cheers,
-i
I’ll ask on OpenLayers users forum! Thanks you all for your answers!
doubt
about it… The example shows how to change the
according
just
response
work out that you shouldn’t make a request to it depending on your
style.
you are using.
Ian
Ian Turton
ThinkGeek and WIRED’s GeekDad team up for the Ultimate
GeekDad Father’s Day Giveaway. ONE MASSIVE PRIZE to the
View this message in context: http://old.nabble.com/Activate-layer-by-zoom—SLD-tp28903447p28904004.html
