I have been asked to implement Microsoft Active Directory Federation
Services as an identity provider and I was wondering if it would be possible
to use the credentials the user enters at the prompt for Active Directory
Federation Services to access resources within Geoserver?
In the past, I have implemented a Shibboleth IDP and the HTTP header
authentication within Geoserver to achieve this and did so successfully -
but I cannot seem to get it working with ADFS as the IDP. The requirement
is still in place to have a Shibboleth Service Provider protecting the
Geoserver instance.
Any help you can provide would be much appreciated.
Fran
View this message in context: http://osgeo-org.1560.x6.nabble.com/Active-Directory-Authentication-tp5179999.html
Hi Mauro,
I am using a Shibboleth Service Provider, but use IIS as a web server and
have set up Application Request Routing to ensure anything with
"geoserver/web" in the URL is forwarded to port 8080 as part of the standard
Geoserver Jetty set up.
Fran
View this message in context: http://osgeo-org.1560.x6.nabble.com/Active-Directory-Authentication-tp5179999p5180305.html
Hi Fran,
The Shibboleth configuration of the user data to extract from ADFS and forward through the service provider is probably the place to investigate if you cannot get user info in GeoServer.
Have you tried to replace GeoServer with a simple Java servlet (or JSP) to print all the http headers and see if the Shib-* prefixed ones are present and correct?
Thanks
Mauro
2015-01-07 10:18 GMT+01:00 fhmsparkle <Mooref@anonymised.com>:
Hi Mauro,
“geoserver/web” in the URL is forwarded to port 8080 as part of the standard
Fran
Dive into the World of Parallel Programming! The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net
Geoserver-users mailing list
