[Geoserver-users] Add a custom projection in GeoServer???
I'm trying to integrate a cylindrical equal-area projection in GeoSever
(Lambert or Gall–Peters or others) so I put the WKT code (epsg = 54034) in
the epsg.properties file but I have this error message:
Error decoding CRS: Error in "PROJECTION": No transform for classification
"Cylindrical_Equal_Area".
So my questions are:
If GeoServer doesn't include a projection, is it possible to add a
projection just adding a WKT definition in the epsg.properties file? If not
it makes sense because the WKT file just serve to communicate the parameters
to the java code?
So the sentence "Add a custom projection" means that we can change/adapt a
projection existing in GeoServer but no create it?
So, concretely what's the method to use to create a new projection in
GeoServer?
Thanks a lot for your help,
Pascal.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Add-a-custom-projection-in-GeoServer-tp5086524.html
