[Geoserver-users] Add an Oracle view as a featuretype
Hello
I just created a view named TSV_TA_GIS_G5 in Oracle which contain 6 fields:
One containing the Geometry called GEOMETRY and others containing binary
data.
I tried to load the view in Geoserver and i have obtained the following
message:
No geometry column row for srid in table: TSV_TA_GIS_G5, geometry column
GEOMETRY, be sure column is defined in USER_SDO_GEOM_METADATA
I think my problem is that this view has not been declared in
USER_SDO_GEOM_METADATA or the spatial index is missing. Can someone explain
me how to create correctly this view to make it interacting with Geoserver?
Many thanks
Sylvain
View this message in context: http://www.nabble.com/Add-an-Oracle-view-as-a-featuretype-tp17236126p17236126.html
springrider ha scritto:
Hello
data.
message:
Instructions at the bottom of this page will hopefully work:
http://geoserver.org/display/GEOSDOC/Oracle+DataStore
Thanks
It works beautifully
Sylvain
Hello
fields:
data.
message:
explain
Geoserver?
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Add-an-Oracle-view-as-a-featuretype-tp17236126p17274020.html
