[Geoserver-users] Add GML Datasource --> SAXException: Timeout
I'm trying to add GML File as datasource with the gt-gml librairy but
the server throws a SAXException...
The gml file has been validated with XMLSpy ( and the Structure too )
but this exception appear in the console:
WARN [geoserver.action] - Unable to fetch a list of FeatureType names
from datastore.
java.io.IOException: org.xml.sax.SAXException: Timeout
  at org.geotools.xml.gml.FCBuffer.hasNext(FCBuffer.java:291)
  at org.geotools.data.gml.FileGMLDataStore.getSchema(FileGMLDataStore.java:156)
  at org.geotools.data.gml.FileGMLDataStore.getSchema(FileGMLDataStore.java:119)
  at org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(DataDataStoresEditorAction.java:164)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
Caused by: org.xml.sax.SAXException: Timeout
  at org.geotools.xml.gml.FCBuffer.getFeatureType(FCBuffer.java:227)
  at org.geotools.xml.gml.FCBuffer.getFeatureReader(FCBuffer.java:200)
  at org.geotools.xml.gml.FCBuffer.getFeatureReader(FCBuffer.java:188)
  at org.geotools.data.gml.FileGMLDataStore.getSchema(FileGMLDataStore.java:154)
  ... 56 more
If I try the same action with a basic gml file ( 1 lines of 2 points )
the same problem appear....
I suppose that the probleme comes from the structure reading but.....
Any idea??
Simon Janssens ha scritto:
from datastore.
  ... 56 more
That datastore, to my knowledge, assumes you have a schema file with the
same name as your gml file, but with an .xsd extension, sitting next to it.
Serving data out of GML is going to be painfully slow anyways. You should consider using ogr2ogr to convert your GML to something more
amenable to fast web serving, such as a shapefile or postgis.
Andrea Aime
OpenGeo - http://opengeo.org
Adreas,
I've put the structure and the gml file at the same place, the
structure main file and the gml file have now the same name ( except
the extention ). But no change.. I have the same SAX Exception
(Timeout).
I would like to keep the gml file as input with no regards to the speed...
Is it possible to modify the timeout value???
2009/2/17, Andrea Aime <aaime@anonymised.com>:
from datastore.
  at
  at
  at
  at
  at
  at
  at
  ... 56 more
Andrea Aime
I’m trying to perform a test with InlineFeature, using as examples the links:
For this, I downloaded the shape, but can not make the example work, someone has already done this example?
http://giswebservices.massgis.state.ma.us/geoserver/wfs?request=getfeature&service=wfs&version=1.0.0&typename=GISDATA.SCHOOLDISTELEM_POLY&outputformat=SHAPE-ZIP
Best Regards,
Fernando Quadro
http://fernandoquadro.com.br
fsquadro@anonymised.com
Date: Tue, 17 Feb 2009 16:11:04 +0100
To: aaime@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Subject: [Geoserver-users] Re : Add GML Datasource → SAXException: Timeout
Adreas,
I’ve put the structure and the gml file at the same place, the
the extention ). But no change… I have the same SAX Exception
(Timeout).
I would like to keep the gml file as input with no regards to the speed…
2009/2/17, Andrea Aime aaime@anonymised.com:
I’m trying to add GML File as datasource with the gt-gml librairy but
the server throws a SAXException…
from datastore.
at
at
at
at
at
at
at
… 56 more
the same problem appear…
I suppose that the probleme comes from the structure reading but…
Andrea Aime
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Veja mapas e encontre as melhores rotas para fugir do trânsito com o Live Search Maps! Experimente já!
Styling only applies for WMS requests. If you want to create a
Shapefile that contains just some hand-made geometries, you will need to
do something else. A few ideas using GeoServer that come to mind:
* pull the GML geometry out of the SLD you've already written and use
the GML datastore extension to serve it via GeoServer
* make a new, empty PostGIS table and use the WKT encoding to specify
your geometry (it is moderately terser than the GML), serve it via
* make a new, empty PostGIS table and serve it via GeoServer. use
OpenLayers as a WFS-T client to hand-draw your custom geometry.
It might be easier to just use a desktop application such as uDig or
QGis.
Hope this helps.
David Winslow
OpenGeo - http://opengeo.org/
On Tue, 2009-02-17 at 16:36 -0300, Fernando Quadro wrote:
I'm trying to perform a test with InlineFeature, using as examples the
links:
- http://geoserver.org/display/GEOSDOC/OGC+SLD+Explanations+and
+Samples
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wms:sld:inline_feature&s=sld
Best Regards,
Fernando Quadro
> From: cid.le.dingue@anonymised.com
> Subject: [Geoserver-users] Re : Add GML Datasource --> SAXException:
Timeout
> Adreas,
> (Timeout).
speed...
> >> Hi all,
but
too )
names
> >> from datastore.
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> ... 56 more
points )
but.....
with the
next to it.
more
> > Cheers
> > Andrea
> > Andrea Aime
Francisco, CA
Enterprise
participation
code: SFAD
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
______________________________________________________________________
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Fernando Quadro ha scritto:
I'm trying to perform a test with InlineFeature, using as examples the links:
- http://geoserver.org/display/GEOSDOC/OGC+SLD+Explanations+and+Samples
- http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wms:sld:inline_feature&s=sld
Never tried out the MASSGIS example, but have you checked out the
ones included as demo calls in with the GeoServer releases?
Andrea Aime
Andrea,
I dont see the included in Geoserver, where are they?
Best Regards,
Fernando Quadro
http://www.fernandoquadro.com.br
Date: Wed, 18 Feb 2009 08:48:02 +0100
To: fsquadro@anonymised.com
Subject: Re: [Geoserver-users] InlineFeature - How use?
links:
Andrea Aime
Under demo requests, for example http://sigma.openplans.org/geoserver/demoRequestSubmit.do
-Arne
Andrea,
Best Regards,
Fernando Quadro
> From: aaime@anonymised.com
> > Hi,
> > links:
> Cheers
> Andrea
> Andrea Aime
Veja mapas e encontre as melhores rotas para fugir do trânsito com o Live Search Maps! Experimente já! <http://www.livemaps.com.br/index.aspx?tr=true&gt;
Arne Kepp
