[Geoserver-users] Add Multiple Layers to Store
Hello, I am pretty new here, so bare with me. I have tried to search but a
lot of links on previous posts do not work, so I'm forced to ask again.
I have worked out some Blue Marble Tiffs and added them. However I was
seeing if its possible to add 2 GeoTiffs to the same Store. Right now I have
them as two different stores, and made them into a layer group. But is that
the best way to do it? If I had a bunch of GeoTiffs, do I really need to
make a store for each one?
Also I finally figured out how to get GDAL on GeoServer. I have about a 1TB
of RPF A.TOC and other various formats that I would like to get loaded into
GeoServer as well. Is this also the only way to do it? there are countless
GeoTiffs for any given area, so a different store for each seems like a bit
overkill? wouldn't adding different layers to each Store for each "area" be
better?
Lastly, Is there a way to add an entire folder and have it search for all
the RPF A.TOC files? I have one Folder name "Florida" inside that folder
are 4 other folders labled "CB01" "CB05" "CB10" "CDRG" inside of those is
more. I am assuming the CB01/05/10 folders are like Pyramids for the data.
but CDRG has other folders "GNC, JNC,JOG,LFCDAY, etc" all of which have
A.TOC files. adding them all is a pain.
Jason
View this message in context: http://osgeo-org.1560.x6.nabble.com/Add-Multiple-Layers-to-Store-tp5291287.html
I think what you are looking for is an image mosaic (where you put your two files into a folder and publish the folder as an image mosaic).
lot of links on previous posts do not work, so I’m forced to ask again.
overkill? wouldn’t adding different layers to each Store for each “area” be
better?
the RPF A.TOC files? I have one Folder name “Florida” inside that folder
are 4 other folders labled “CB01” “CB05” “CB10” “CDRG” inside of those is
but CDRG has other folders “GNC, JNC,JOG,LFCDAY, etc” all of which have
Jason
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Jody Garnett
