How add new EPSG in the GeoWebCache? I would like add EPSG:4674!
Best Regards,
Fernando Quadro
Moderator GeoServer-BR
Best Regards,
Fernando Quadro
Hi Fernando, slow response due to vacation.
The documentation [1] shows you how to add layers or additional grid definitions. Put the resulting geowebcache.xml file into <GEOSERVER_DATA_DIR>/gwc , and it should be read next time you restart GeoServer.
The easiest thing is to start with the default configuration file and modify it to your needs. Let me know if anything is unclear.
-Arne
1: http://geowebcache.org/trac/wiki/configuration
Fernando Quadro wrote:
Best Regards,
Fernando Quadro
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
