I everyone, I wrote you cause I need help. I am dealing with geoserver and openlayers a few days ago througth a MySql spatial database. About WFS-T there’s an openlayers example that show in some way how to do so. But me I don’t want to draw the feature. what I want is put data in an html form (by ex latitude, longitude) and then when I click on ok button just call a method that will create the feature and do the WFS-T insert. I found nothing on the net that hadle that! If anyone can help me? Regards! Bernony
If you can't find a prebuilt library to your purpose, you could use a simple CGI script or servlet to intermediate. You could pass the information as key-value pairs directly from the form and use your choice of language to build it into a proper WFS-T message.
Otherwise, you might want to look at Community MapBuilder. One of their WFS-T examples offers functionality something like what you are describing.
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Oct 30, 2008, at 1:12 PM, berno wrote:
I everyone, I wrote you cause I need help. I am dealing with geoserver and openlayers a few days ago througth a MySql spatial database. About WFS-T there's an openlayers example that show in some way how to do so. But me I don't want to draw the feature. what I want is put data in an html form (by ex latitude, longitude) and then when I click on ok button just call a method that will create the feature and do the WFS-T insert. I found nothing on the net that hadle that! If anyone can help me? Regards! Bernony
View this message in context: adde feature (WFS-T insert) with opelayers by using an html Fom
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world http://moblin-contest.org/redirect.php?banner_id=100&url=/_______________________________________________
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Veja mapas e encontre as melhores rotas para fugir do trânsito com o Live Search Maps! Experimente já!
You will get a better answer to this query on the openlayers users list. But this is definitely something that should be pretty easy to do with openlayers.
You should be able to set up a regular wfs-t layer in openlayers as you usually would. And then instead of using the edit tools to create new features, you can do it manually based on the inputs of your form.
I don't know the code for creating a feature manually in this way but again but the folks on the openlayers list will.
-Justin
View this message in context: adde feature (WFS-T insert) with opelayers by using an html Fom <http://www.nabble.com/adde-feature-(WFS-T-insert)-with-opelayers-by-using-an-html-Fom-tp20251287p20251287.html>
Sent from the GeoServer - User mailing list archive <http://www.nabble.com/GeoServer---User-f1194.html> at Nabble.com.
I believe you have found a bug. Usually lock requests are performed via a POST request, however its 100% according to the spec to do them by GET requests.
A LockFeature request must contain at least one LOCK element
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
I don't have finding examples for WFS-T requests.
Best Regards,
Fernando Quadro
GeoServer-BR
Date: Thu, 30 Oct 2008 10:12:01 -0700
Subject: [Geoserver-users] adde feature (WFS-T insert) with opelayers by using an html Fom
Veja mapas e encontre as melhores rotas para fugir do trânsito com o Live Search Maps! Experimente já! <http://www.livemaps.com.br/index.aspx?tr=true>
Hi Justin
Thanks for your help.
I've just found how to do so. The fact is in Geooserver there's a page with
many examples of wfs-T queries and it is possible to get the javascript
code. I just have to create manually the query and post it with a submit
form.
Bernony
Justin Deoliveira-6 wrote:
Hi Bernony,
openlayers.
-Justin
Regards! Bernony
challenge
prizes
Justin Deoliveira
OpenGeo - http://opengeo.org
challenge
prizes
