Hii
I want to add a new feature layer in POSTGReSQL from open layers.
I got the answer from openlayers forum as...
http://osgeo-org.1560.x6.nabble.com/creating-a-new-layer-in-database-td5089934.html
Using openlayers directly you can't do this:
You need to call from openlayers some server-side code (i.e. java or
c# or whatever you wanna use) that, in order:
1. enstablish a connection to postgres db
2. launch a series of sql commands that create a table, fields,
indices and so on
3. call the geoserver rest api and configure geoserver accordingly:
I have created table using the c# code.
Now I want to publish a layer in GeoServer using REST API.
I saw the documentation of GEoSevver. I could not find anything which can
help me do this. I can see the existing layers, workspaces etc. but I cannot
create any layer.
Any help..
Thanks and Regards
Pankaj Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/adding-a-layer-in-Geoserver-using-REST-API-from-the-POSTGreSQL-Table-tp5090538.html
Have you read and tried this recipe http://boundlessgeo.com/2012/10/adding-layers-to-geoserver-using-the-rest-api/ ? If it does not work for you, tell where it fails and what happens. Describe then also your environment (Geoserver version, jre version...)
-Jukka Rahkonen-
pankaj123 wrote:
Hii
td5089934.html
You need to call from openlayers some server-side code (i.e. java or c# or
1. enstablish a connection to postgres db 2. launch a series of sql commands
that create a table, fields, indices and so on 3. call the geoserver rest api and
I saw the documentation of GEoSevver. I could not find anything which can help
me do this. I can see the existing layers, workspaces etc. but I cannot create any
layer.
Any help..
Thanks and Regards
Pankaj Bansal
tp5090538.html
Shape the Mobile Experience: Free Subscription Software experts and
developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ciao,
take also a look here:
http://docs.geoserver.org/latest/en/user/rest/examples/index.html
You can find samples to publish, modify and create new resources in geoserver using curl and much more.
Here is the reference manual:
http://docs.geoserver.org/latest/en/user/rest/index.html
Carlo
2013/11/21 Rahkonen Jukka <jukka.rahkonen@anonymised.com>
Have you read and tried this recipe http://boundlessgeo.com/2012/10/adding-layers-to-geoserver-using-the-rest-api/ ? If it does not work for you, tell where it fails and what happens. Describe then also your environment (Geoserver version, jre version…)
-Jukka Rahkonen-
pankaj123 wrote:
Hii
I got the answer from openlayers forum as…
td5089934.html
Using openlayers directly you can’t do this:
- enstablish a connection to postgres db 2. launch a series of sql commands
layer.
Any help…
Thanks and Regards
Pankaj Bansal
tp5090538.html
Software experts and developers: Be at the forefront of tech innovation.
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
mobile: +39 3371094494
