[Geoserver-users] Adding a new field to PostGIS DB?
Hello List,
I’ve got Geoserver 2.8.3 serving from a PostGIS DB, no issues.
I’ve added a new field/column to an existing table in PgSQL.
I thought that new field would just show up in GeoServer… but I’m not seeing it there.
I’ve also deleted the Layer in GeoServer and re-published it… and it’s still not seeing the new field from the DB.
Is there something special that I need to do to make the new field “known” to GeoServer?
thanks,
John
Ciao john,
in the layer config there is a "reload feature type" button to do
reload the table config from the database.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Jun 3, 2016 at 10:33 PM, John McCarty <johmcc1138@anonymised.com> wrote:
Hello List,
thanks,
John
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Thanks Simone,
I had seen that, and tried it… it worked now… but only after I had updated the new field to have some data/values in it. Initially, the field was empty for all records.
Not sure why that would have any effect, but it seems to have.
thanks again!
John
On Jun 4, 2016, at 4:19 AM, Simone Giannecchini <simone.giannecchini@anonymised.com107...> wrote:
Ciao john,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hello List,
thanks,
John
