Ciao Greg,
I would probably use etopo1 instead of gtopo30.
As of putting this kind of tiles together, I guess that the
imagemosaic is you friend in this case. Honestly I have never tried to
use it that way, hence I am not sure it would work out the box since
gtopo is a raw image format with other information stored in ancillary
files and that's not really what the imagemosaic was originally built
for. Anyway, this could work via the imageio-ext gdal plugins.
Baseline is that I would need to test it a little bit.
Of course converting to geotiff and then mosaicking is always an option.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Mon, Dec 15, 2008 at 7:40 PM, Greg Ederer <greg@anonymised.com> wrote:
I have been asked to add a topo layer to our GeoServer/OpenLayers
application. I have found a number of global topographical coverages.
The two that I am considering right now are GTOPO30 and ETOPO1. Does
anyone have any kind words of advice as to what coverage I should use?
(I hope it's OK to ask this on this list).
Secondly, these datasets are distributed as tiles. I have tried loading
a few of the GTOPO30 tiles into GeoServer, which works perfectly
(thanks, GeoServer team!) What is the best way to combine these tiles
into a single OpenLayers layer?
Thanks!
Greg
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| greg@anonymised.com
| 360.774.6848
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can't happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/
Geoserver-users mailing list
