[Geoserver-users] Adding an existing shapefile
Dear Friends:
What I want to do is publish a shapefile that already exists on the server. The shapefile on geoserver locates at data/ChinaMap/newLine/newLine.shp. My request is below:
url = "http://localhost:8080/geoserver/rest/workspaces/ChinaMap/datastores/newLine/external.shp";
data = “file:///data/ChinaMap/newLine/newLine.shp”;
curl_easy_setopt(_curl_handle, CURLOPT_USERPWD, userPassword.c_str());
curl_easy_setopt(_curl_handle, CURLOPT_URL, url.c_str());
curl_easy_setopt(_curl_handle, CURLOP_CUSTOMREQUEST, “PUT”);
curl_easy_setopt(_curl_handle, CURLOPT_HEADER, 1);
headers = curl_slist_append(NULL, “Content-Type: text/plain”);
curl_easy_setopt(_curl_handle, CURLOPT_POSTFIELDS, data.c_str());
curl_easy_setopt(_curl_handle, CURLOPT_POSTFIELDSIZE, strlen(data.c_str()));
curl_easy_setopt(_curl_handle, CURLOPT_HTTPHEADER, headers);
curl_easy_perform(_curl_handle);
But I get the response is http 400 bad request, failed to locate the input file file:/data/ChinaMap/newLine/newLine.shp.
Who can help me??? Thank you!!!
The GeoServer documentation can help you! :slight_smile:
See:
http://docs.geoserver.org/stable/en/user/rest/index.html
http://docs.geoserver.org/stable/en/user/rest/api/index.html#rest-api
http://docs.geoserver.org/stable/en/user/rest/examples/curl.html
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Fri, Aug 29, 2014 at 10:21 AM, fanxing926 <fanxing926@anonymised.com> wrote:
Dear Friends:
    url =
"http://localhost:8080/geoserver/rest/workspaces/ChinaMap/datastores/newLine/external.shp&quot;;
    data = "file:///data/ChinaMap/newLine/newLine.shp";
    curl_easy_setopt(_curl_handle, CURLOP_CUSTOMREQUEST, "PUT");
    headers = curl_slist_append(NULL, "Content-Type: text/plain");
Slashdot TV.
Video for Nerds. Stuff that matters.
http://tv.slashdot.org/
Geoserver-users mailing list
